SIMBA Fibre Broadband
hi may I ask why the M1 6gb is better than simba 10gb where it is cheaper at $30/mth?
M1 6Gbps offer (S$34.90 per month or S$35.90 per month with free Archer BE805) is way better than the offering from SIMBA.
IMHO I do not think it is worth considering SIMBA now.
1) New users --> worse support compared to M1
2) Power users --> CGNAT
3) Effective pricing --> M1 is cheaper
Anyway, this is just my personal opinion. You can come to your own conclusion.
TP-Link Archer BE805 is worth about S$270 to S$300 BNIB in Carousell. Even if you just consider it at S$240, the effective price of M1 6Gbps is at S$35.90 - S$240/24 = S$25.90 per month.
M1 --> dynamic public IPv4, better routing (latency) to other local and internation websites, IPv6, free digital voice
SIMBA --> CGNAT without static IPv4 add-on (not possible to get public IPv4 address) worse latency, IPv6, no digital voice. 10Gbps and 6Gbps no real difference to 99% of the customers.
Problem with CGNAT:
https://en.wikipedia.org/wiki/Carrier-grade_NAT
Critics of carrier-grade NAT argue the following aspects:
  • Like any form of NAT, it breaks the end-to-end principle.[6]
  • It has significant security and reliability problems[clarification needed], by virtue of being stateful.
  • It does not solve the IPv4 address exhaustion problem when a public IP address is needed, such as in Web hosting.
  • It may create a performance bottleneck that limits scalability.
  • Carrier-grade NAT usually prevents the ISP customers from using port forwarding, because the network address translation (NAT) is usually implemented by mapping ports of the NAT devices in the network to other ports in the external interface. This is done so the router will be able to map the responses to the correct device; in carrier-grade NAT networks, even though the router at the consumer end might be configured for port forwarding, the "master router" of the ISP, which runs the CGN, will block this port forwarding because the actual port would not be the port configured by the consumer.[7] In order to overcome the former disadvantage, the Port Control Protocol (PCP) has been standardized in the RFC 6887.
  • In cases of banning traffic based on IP addresses, a system might block the traffic of a spamming user by banning the user's IP address. If that user happens to be behind carrier-grade NAT, other users sharing the same public address with the spammer will be inadvertently blocked.[7] This can create problems for forum and wiki administrators attempting to address disruptive actions of a single malicious user sharing an IP address with legitimate users.
  • Streaming media services may see CG NAT activity as equivalent to Virtual Private Network or Account sharing traffic. Such services often block or ban VPN users for breaching terms of service under an assumption they are accessing content from a cheaper region in an attempt to pay less money for the service, and account sharing traffic being blocked for multiple distinct households or users accessing the content for the price of one login.
NoTimeToWaitAr
thank you. currently I'm using 1gb M1 super old contract at 37$. thinking to switch to other plans or ask for discount as the latest plan is even cheaper that what I'm paying.
just to aks, when I did a speed test near to my router, the download speed is less than 200mbps. is that normal? I'm using phone wifi for the speed test if that matters.
It will depend on your old router and your phone. No supprise if you use very old M1 issued routers.
Old M1 router may be out of security updates support and it can pose a security risk to your home network, like Asus RT-AC1200G+ and RT-AC2600.
Reference: Asus EOL list
https://www.asus.com/event/network/eol-product/
You should check with M1 to see if you are eligible for the S$32.90 per month 6Gbps offer with free Archer BE805. That is a superb recontract offer.
Please go to M1 thread since this is not related to SIMBA.
iceoxfch
Just received this from SIMBA. Any idea what ONT SIMBA would upgrade us to?
xtemujin
Simba only sent the timing slot but not the date.
I'm not taking leave just to wait for them to deliver the ont as in the past we collected it from the shop vendor and installed it by ourselves.
galliano
Started with SIMBA last Nov. I too got the email. "No head no tail".
I wonder why and what time also?
Nakedtoes
Wtf is simba broadband getting worse? Knn nowasday always loading even for YouTube at 720p
..wtf...
So I received the ONT change and I think I am one of the first ones to get it done, since no one else talked about it.
Essentially its the same ONT model but with some software updates.
Asked the installer why the change, and he said that it makes the network more stable.
Installer did a Speedtest using SIMBA server and his laptop with a thunderbolt 10GBPS network adapter and its about 8-9 GBPS range.
Don't see any difference IRL for speed or latency since the change yesterday morning for me.
I am on 2.5GBPS router only and have not maxed out the bandwidth yet.
