SIMBA Fibre Broadband
Nakedtoes
Simba ONT must be installed by their appointed technician?
can we self collect and install?
That time the technician use his phone to scan the QR code in the email and the ont. So not sure u can install yrself.. Can email them.
musing
Installed Simba 2 days ago. Router: TpLink Archer72 AX5400.
Ethernet CAT 6 downloads/uploads 450/550mbps from tvbox.
Wifi 350/400 mbps
2 days ago using 5 year old TpLink EA1900 WiFi only like 200/250mbps
Any advice what else I can do to improve speed?
Nakedtoes
Wifi 350/400 mbps
U try speedtest from GSL Singapore or digi KL... Likely can get 1.5 to 1.9gbps for wifi.
buttertrade69
when using wifi to do test, it is also subjective to your device. When i do test with both Dell laptop and Macbook Air. Same distance and both connected to same AP with Wifi 6 connection. My Dell only can get 100plus mbps but my Macbook Air can get 200plus. My Dell laptop can only get 200plus is I just place my laptop next to my AP. My Samsung phone even worse not matter where i do the test, with wifi 6 i can only get 60plus mbps only.
kennethoka
For those who do speedtest, please do take note that by default the unit is Mbps but some might accidentally select MB/s. for MB/s you might find your result is much lower because Mbps = 8 * MB/s
dgeralds
I got asus tx-Ax6000 from taobao weeks ago.. Recieved few days ago.. Now u order prepare for delay.. Most shops in taobao already closed and in holiday mood. Price is abt 150 for Asus tx-Ax6000 or the xiaomi be7000. Xiaomi is wifi 7 router with 4 x 2.5g lan port but only Chinese interface. I go with Asus as I am more familiar with their interface. The local version AX6000 is selling at 300.
Is the asus tx-Ax6000 from taobao is English interface?
Nakedtoes
Thanks Nakedtoes.
Can you give the link to buy asus tx-Ax6000 ? I will ask my fried to buy as I have difficulty buying from chinese website. Thank you.
DO get voucher to bring price to rmb 749...then use sea shipping is free.
【淘宝】https://m.tb.cn/h.5HHGBbGabda7lgK?tk=1J6MW9zAnhq MF1643 「华硕(ASUS)天选游戏路由器无线千兆家用WiFi6双频双2.5G口疾速AX6000M组网AiMesh2.0网易UU电竞提速」
点击链接直接打开 或者 淘宝搜索直接打开
dgeralds
If anybody buying asus tx-Ax6000 (china version), I would like to join. Please PM me. Thank you.
tokenbest
Hey, just wondering if did you try using their AiMesh or only 1 standalone unit for now haha.
Thinking if need to get 1 or 2 if buying for mesh
Nakedtoes
I tried mesh with my ac68u over lan.. Cause my room got layed with lan cables.. But I dun see any need as a single Tx-Ax6000 is very powerful to cover mine whole 5 room hdb.. The lowest corner I also can get 300plus mbps..
If u going to mesh with wifi the result might not be good.. Mine advice is get 1 pc only and try.. Good router positioning is important.
You may want to post the floor plan to see if single router is good enough or not. Placement is key. You need to indicate the location of the ONT and LAN ports in the rooms, as well as the intended placement of the main router and mesh node.
And as answered by Naketoes, usually you start with single router first to see if it is good enough or not, then you add the mesh node when necessary.
Sometimes you may have to put a router in the DB box to make use of the LAN ports in the roooms, and then you may need to have a mesh node if the DB box blocks WiFi badly.
If your room has no LAN ports, then it depends on whether it is possible to put the main router in a central location or not.
Anyone know if got IPv6?
Nobody has reported on this one yet.
@Nakedtoes
Just wondering if you can help here or not. Enable IPv6 in your TX-AX6000 to see if IPv6 works or not. You can follow the following settings. Then you can carrry IP v6 test at https://test-ipv6.com/.
