Sounds like a backend issue and not an ONT issue or your computer.Day 11 without usable internet service. The technician they sent down is of no help. He is contractor for SIMBA, their main job is to do the installation for new sign-ups and all the guy did was check the ONT modem, FO cable ethernet cable are working. He did a speedtest on his iphone 15 pro max, his company laptop, all gave the same result of less than 1mbps of speed. He did not bring down a spare ONT modem to test because SIMBA did not approve it and the trip was just to verify the issue I described. He then came back again in the afternoon, probably after reporting back to SIMBA, they decided to place ONT modem which gave the same results.
TDLR - issue not fixed, no improvements, haven't gotten back to me whats next. most likely moving into the weekend with 13 days of no service from SIMBA.
P.S technician told me i am not the only user experiencing such issue, there are many and he doesn't know what is the eventual outcome or solution
They used some kind of device to test the FO wire, the FO port, no abnormality.Since their subcon tech tested ont using their own eqt, user problem is avoided.
Did they happen to test the optical power at the source with another FO patch cord and then thru ur FO cord?
If signal is good range then is simba backend problem liao, not the UE nor infra liao.
Feedback to IMDA.They used some kind of device to test the FO wire, the FO port, no abnormality.
Day 14 without any solution or timeline from SIMBA.
I understand majority of the users have no issue, but beware that once you kena, you will wish you never touch SIMBA.
try speedtest.sgix.sg?Just wanted to add i connected to simba about 3 weeks ago but only today i bring laptop with 2.5g usb ethernet to test myself (house still renovation).
Using same laptop + usb dongle:
Starhub - at current place d:950 u:950
Simba - at place under reno: d:200 u:800...
The support ask me to connect to ONT directly and do 3 speedtests and send picture of proof of my set-up. Tomolo go onsite and check again. given how i've nothing connected at the reno house and the download is 200mbps while the upload is 800... my guess its' their back end got congestion, but they said they won't escalate unless i submit my test results first.
Sian man. already regretting signing up and i haven't even move in.
Location?Just wanted to add i connected to simba about 3 weeks ago but only today i bring laptop with 2.5g usb ethernet to test myself (house still renovation).
Thanks sir - will give it a shot tomorrowtry speedtest.sgix.sg?
They are peering at sgix so you should be able to at least get 1gbps up and down.
Central/Adam Road areaLocation?
i also m1 (500Mbps) super reliable and my cheap ax10 tp-link router always uptime without rebootAfter reading all the feedback. Think I just stick to M1 500mbps plan. Almost 5yrs I think.Is whizz comm gd
U also thot sign up simbai also m1 (500Mbps) super reliable and my cheap ax10 tp-link router always uptime without reboot
yes like day 1 with tpg. my area not coverU also thot sign up simba
For those keen on Simba router, they are selling these:
Dear customer, should you require a 2.5G router that’s compatible to your SIMBA Broadband 2.5Gbps service, we have options for you!
1) TP-Link Router Archer AX55 Pro V2 2.5G (Compatible 2.5G Router)
(c/w 1 x 2.5G WAN port & 1 x 2.5G LAN port) @ $305.20 nett
2) Ruijie Router 3200 @ $216.91 nett
