sj4000 vs gopro3
Ringwraiths
can bring the hero 3 go for swimming and diving ?
Both Gopro and SJ4000 Comes with a underwater housing which enable for swimming or diving.
Gopro3 up to 60m
Gopro3+ up to 40m
SJ4000 to 30m
Correct me if i m wrong
Ringwraiths
Thanks. 32Gb is what is officially supported, but I'm just interested to find out whether anyone actually tried to stick a 64Gb in there.
Yes max its 32GB but hmmm i havnt tried for the 64GB if it can support not.
Ideal its 32GB with Class 10 - Faster write speed and not laggy.
sinmarket
For most Nand flash or memory card, USB, SD card from low capacity to max 32Gb it is using standard FAT system.
For cards beyond 32GB it is using different command of system to store data. Thus the device must be able to handle this function.
I do not have 64GB micro SD with me to test. I find it too expensive and heart pain if I loose the card. Since the manufacturer say Max 32GB, I don't think it works with 64GB. :)
Ringwraiths
Btw I just checked mine Hero3 Spec...it indicate "Support MicroSD Cards up to 64GB" so i guess 64GB card can be used.
sinmarket
Hero 3 or 3+ and AEE SD21 model and above support 64GB.
They are running on much advance processor.
Video Camera are meant to be short clip.
I see no point investing on high capacity card.
circuitbreaker
Anybody know if qoo10 is a reliable source for go pro? Their selling the gopro3+black for just 485
Apparently have good reviews and comes w one year warranty
Streetwise
qoo10 is like every other e-commerce sites like DX, aliexpress, etc, etc. They're the middleman for buyers/sellers. U hve to do ur own research. For high value product, if there is a physical shop in S'pore, tat would be great as u can revert to it for any issues...but this is no guarantee tat u getting the real or good deal. Eg, warranty can mean inshop...which means it is not covered by manufacturer.....thus, u've to make ur due diligence before making a decision....remember.....caveat emptor.
veryred
How is the stills quality compared to gopro?
This is with a gopro hero 3 silver ed
this is with sj4000
same place but different angle.
The main difference is that the sj4000 gets really really blue in the picture. Some people likes the vibrancy of the colour but I don't.
Overall the image quality is still ok. For the price I am paying, I will say it is worth it.
sinmarket
Taken with POSH SJ4000.
No tripod.
Picture Pixel = Max
Picture Quality = Normal
HDR = ON
Stabilizer = ON
starbugs
I just got my SJ4000. Plugged in my Sandisk 64GB MicroSD from my other camera. Seems to work well
camelsback
No tripod.
Picture Pixel = Max
HDR = ON
Stabilizer = ON
this is with sj4000
Thanks. The max is 1080 resolution right? With enough lighting is it blur? Cos I know sj for night stills is very very bad
sinmarket
1080 setting is for the video.
For the still I set to the max megapixel.
These cameras as meant for video thus I don't expect good quality picture.
This applies to all action cameras.
Cheers
sinmarket
POSH SJ4000 available in Challenger outlets
I think there is Free gift for Members. :D
Funan
Parkway
Tampines
Vivo City
Plaza Spore
IMM
JEM
Jurong Point
NEX
:s12:
