Starhub 1Gbps Fibre Review
y2k_tay
Can i ask if recontract, they offer a 3 month waiver as a default?
went down to PS to recontract yesterday.....given free 6+3mths for 1Gps BB @39.9mth.....27mths contract...no free WiFi router which I no need, prefer frill-free...so effective sub is 26.60mth ...money saved can use to buy a better router than the free ones...or as savings...359.10.....
qwerty_hippo
Is the Nokia mesh router better or should I stick to their old linksy wifi router?
planning to upgrade my Ethernet cable to cat7/8
KYZT2021
Can the other ports on the ONT be use to connect to computer direct for internet?
No.
ONT Port 1: the only port active for 500Mbps and 1Gbps plan
ONT Port 2: for those with Fibre TV (not the new Starhub TV+ Box)
ONT Port 3: second port active for those with Starhub 2Gbps plan (two networks, two public IPs).
If your Linksys works fine, then no need to change. Nokia Beacon 1 is a lower end AC1200 grade router compare to the AC2600 grade of Linksys EA7500 v2 and EA8100 v1.
Main advantage of Nokia Beacon 1 is that you can buy one more unit to form a mesh, and it supports wireless connection of Starhub TV+ box. Linksys EA7500 V2 and EA8100 V1 only support wired connection to Starhub TV+ Box.
MIVEC525
Presently using my D Link router, re contract got the Nokia Beacon 1, need to change for better wi fi coverage, or not much difference? Coz only 1 port out for Lan. So still thinking to change or sell away...thanks!
Most of the reports here say that Nokia Beacon 1 is worse than DIR-868L, EA7500 v2 and EA8100 v1, interms of wireless coverage. But YMMV. Resale value is low due the low rating of the Nokia.
If your existing D-Link is functional, then probably no point to change and then you can sell your Nokia Beacon 1. If your existing D-Link is not good enough, you can get another D-Link or get an EA7500 v2 which probably performs better than the D-Link.
MIVEC525
Thks for replying....my present D Link still ok...coz got 6 IP cams and 1 doorbell to configure....troublesome...guy ask me to get 1 to 4 Lan port coz behind only 1 Lan output...was disappointed. When put the 4 port does it worsen the speed?
MIVEC525
If you use the Nokia Beacon 1, yes it is good to add a switch like TP-Link TL-SG105 to have more LAN ports. Performance will not be affected.
MIVEC525
Ok...i chk lazada...anyway got ppl offer $60 to buy my nokia beacon...buy switch or sell beacon?
Henry Ng
Not correct. EA8100 V1 also can support Starhub TV+ box using wifi but can not watch FTA channels if on wifi. It can watch FTA channels only with a wired connection.
