Starhub Giga
Fellowes
So far after using my current Giga 5G eSIM for a fortnight, its a mixed bag as I can't get 5G inside most buildings indoor. Even at home with open window also about 2 bars. Certain mall basement can get full bar though..
StarHub 5G coverage still cannot match SingTel 5G. Maybe give them time to improve the coverage, should be better by 2025.
Fellowes
When it falls back to 4G I get 3-4 (full) bars though.
I am on giga 5G SA. Turning off SA on my Samsung S24 Ultra always falls back to 4G.
On MRT almost always on 4G..
Should by right fall back to 5G NSA then 4G. On MRT depends on which MRT line and telcos.
By July should be this sequence:
5G SA —> 5G NSA —> 4G
MoneyFace =p
Huh? Really. StarHub 5G should be okay but of course cannot match SingTel 5G. Overground with my SingTel SIM ONLY is almost all 5G
I was on train from City Hall to Bedok and throughout has been consistently 4G.
Not even 4G+ unlike my GOMO 4G on secondary line.
joel_winston
Do Giga use 5G NSA? I also never seen it. I rather Giga fall back to NSA than 4G. At least is less crowded.
Fellowes
If have 5G SA definitely will have 5G NSA, it won’t shown on the status bar as usually is just 5G, just that in the phone setting should have 5G stand-alone toggle. If you off the toggle and still connect to 5G then is 5G NSA. you will see the signal bar searching and reconnect will you toggle the 5G SA option.
Tedicious
On android device you can tell if it's SA or NSA
MoneyFace =p
On my Samsung S24 Ultra, turning off SA option immediately switches to 4G and vice versa. So don't think NSA 5G is working well for Giga..
sibeiTrolled
isn't GIGA 5G SA?
Sim status on my phone states NR, so does GIGA website https://www.giga.com.sg/TnC
3.30.1 The giga! 5G Standalone (“SA”) is a service which enables mobile data access on 5G SA network at no extra cost to customers.
Fellowes
Or maybe NSA doesn't exist at all
Or are they like M1, currently only have 5G SA + 4G?
The upcoming removal of 3G on 31 July 2024 from all main telcos, so no need to mention.
Can we confirm these:
SH/M1: 5G SA + 4G
ST: 5G SA + 5G NSA + 4G
SIMBA: 5G NSA + 4G
Tedicious
SH/M1: 5G SA + 4G
SIMBA: 5G NSA + 4G
I do experience 5G NSA on circles life (M1) on Samsung S23. You can tell.if it is a SA or NSA by the 5G icon
Fellowes
I thought M1 always say their is “true 5G” which is the first to introduce 5G SA when their 5G launched as they issued with only 5G SIM Card, then all the iPhone 12 series got remove from M1 5G certified devices as that only support 5G NSA. It’s was an issue back then.
MoneyFace =p
Just did a round island tour today and I have to say the entire SLE and TPE stretch of SG has great giga 5G signal. Entire BKE was 4G throughout and PIE was good on the east and getting worst towards the west.
Tedicious
West is always bad on starhub. DK why
