[Temperature] CPU & GPU idle & load running temp - Please share here!!
royfrosty
i see. still considering to replace the stock heatsink of the CPU or not.
don't think there will be much difference in terms of the temperature right?
With stock Intel on idle it should be 43. Running prime 95 for 30mins it should hit 80.
With Gaia on idle 32. With load max 71.
I went further to use Arctic silver thermal paste. idle 31. With load 68.
tony_ong
i see. mine now when i play dota 2, it hits 64 max on stock. tried prime95 before but forgotten the temp.
royfrosty
may i know which shop listed at $35?
also, any recommendations for case fan?
thanks
Tradepac. But I think when I was there I sapu the last set lol.
If dont have, Can find other store also like cybermind. pcthemes at $37.
shadow84
hmmm wonder if it can fit my case with top case fans mounted. :s22:
CM Elite 430 Max CPU Cooler clearance : 163mm
Xigmatek Gaia height: 159mm
Difference of 4mm... Gonna cut it close....
You can go dl their user manual... Got all of the dimensions at last page.... and try measure from middle of cpu to your fan.
royfrosty
for my t28 I got 6mm allowance left.
tony_ong
it means without a top fan it will be able to fit?
Kukuza
Wah! I love your gfx card temp. What id the brand and model?
What cooling solution you using? Water cooling?
It's MSI 760 Hawk .
I have a fan at hdd cage to help channel air to gpu area .
not water cooling . just air cool rig .
i1magic
It's MSI 760 Hawk .
Wah, your gfx card's fan only 900rpm and temperature at 37degC only. That's very good leh.
MSI Twin Frozr really is really 名不虚传. Maybe I should find a way to mod my gfx card's heat sink and fan.
fokgola
is this temperature ok? the max is running on BF3 ultra setting.
tamjinhang
temp config for now.... load temps based on hyperpi and heaven benchmark 4.0
running at room temp, hardly any ventilation for surroundings.
