[Temperature] CPU & GPU idle & load running temp - Please share here!!
Mythmaker
If you watercool, your GPU temps probably around 38 and load around 42.
That's how bad GPU coolers are lol.
i1magic
If add this, would it help?
Item : PCI slot bracket with 2 x 80mm fan
Price : About SGD$24
Source :
PCI Slot System Video Card Cooling Fan Cooler 2 x 80mm | eBay
Mythmaker
[/IMG]http://i01.i.aliimg.com/wsphoto/v1/590655715_1/New-PC-Computer-Case-Cooling-System-font-b-PCI-b-font-font-b-Slot-b-font.jpg[/IMG]
Source :
No it won't help. I even mount a Prolimatech MK-13 before with 3x 120mm fans. Sure, the performance trashes all the other air cooler out there but it just can't hold a candle to WC at all. You are better off mounting a Corsair H80 on the gpu (by cable tie it), at least the core temps will be closer to a custom loop.
Mythmaker
Cost effective? If you are daring, probably the Corsair H60 with cable ties :)
shadow84
Diff between H60 and H80 is the corsair link and the inability to control the fans directly, instead it must be attached to mobo?
tony_ong
If you decide to use the stock fan that comes with it, it is quiet.
i see. still considering to replace the stock heatsink of the CPU or not.
don't think there will be much difference in terms of the temperature right?
