[Temperature] CPU & GPU idle & load running temp - Please share here!!
hlots123
Guys I need help. Just built a new PC. CPU is i5 4570, on idle the temps are too high. I reseated the HSF and applied thermal paste but temps still the same. i.imgur.com/1XCEFib.png?1[/url]
help u post pic. is cpu vid always 1.0+v, package power always 17+w constantly? is smthg constantly running in background (...eg virus?)
crazycow
Ya everytime i open hwmonitor to see its running at those values and dunno why cpu meter always around 16% idle. I already did clean install of windows, unless can virus go over to the mobo or other components? If so what should i do? All new parts except hdd and dvdrom :'(
Ps. Thanks for helping me display my picture i dun have enuf credits or something cant show
i1magic
Yes. My rig is also >10kg. Got the standard motherboard, gfx card, big HSF and 4 harddisk and 1 SSD.
After I put the PC on top, I find that it is the best spot if you have space constraint.
Just saw your idle CPU temps @ 33C at ambient of 29C non-aircon. Not bad for a non-aircon room. No OC for yr Xeon?
That one is idle. Close all your browsers and whatever, you may see temperature drop liao.
My this Xeon cannot overclock one. When I do normal work, with all the browsers, Excel, etc running, like now :
Ambient 29degC and cpu is about 37degC and gfx card is 40degC.
i1magic
Help you enlarge it.
i1magic
I'm using a Deepcool Tesseract with 2 stock 120mm fans. I have no graphics card as of yet, waiting for it to arrive. I connect my DVI to my mobo, so Im using the i5 graphics processor.
Yes I turned them back 90 deg I followed the instructions on the intel booklet.
I scared to run stresstest as idle temp already high it might be pushed too much
Where is your casing located in the room? 2 fan stock fan sucking air in or pushing air out?
artyboy
Oh I didn't realize simple tasks like that causes the CPU temps to rise that much.
camelsback
May i employ all your expert opinion on an affordable yet good thermal paste to get?
Could you also suggest places to get them(convenience) and the rough price i should be paying? amazon would be good if theres free shipping!
b3njaminlee
Hi, recently got h100i. 2nd hand tgt good TIM.
However Cpu Temp min = 38
Max 41 - 41 for idle
Is it okay ?
read some other forums, it takes time for TIM to settle down..?
Im not in an AC room. Outside w fan.
royfrosty
Is it okay ?
Very normal. In fact quite good. Remember ambient temperature around there is fine.
naked123
Fractal Design Arc XL
Coolit ECO240 push only
i5 2400 no OC - 36-41 idle / 49 load
7870 OC - 36 idle / 80 load on furmark
BlackCube
Yureak
Is it okay ?
its good temp. good to see my h100i serving you well :)
EV1L
This is mine at normal room temperature. CPU OC to 4.2Ghz with AIO WC.
CPU
GPU
FinalTidus
Hi guys,
New to this thread.
Here are my quick details:
CPU: Load 90C
Idle 50C
GPU: Load 80C
Idle 45C
These figures should be ok right? Maybe the CPU is a little on the warm side for load but should not be a problem right? They say max temp is 105C for the i5-2500k.
i1magic
Hi guys,
New to this thread.
CPU: Load 90C
Idle 50C
GPU: Load 80C
Idle 45C
Are those temperature readings in an aircon room?
FanFreak
Just for sharing
My rig at the side with 2 AIOs.
Idle
CPU oc to 4.4khz, 34-36deg
GPU, 39deg
BF4 load
CPU, 59deg
GPU, 69deg
Intel burn test after 10passes
CPU, 83deg
