[Temperature] CPU & GPU idle & load running temp - Please share here!!
shadow84
H80i on silent mode (pump & fans)
Ambient temp: 28C
Idle:
All cores ~45-46C
SSD Drives ~ 30C
HDDs ~ 35C
GTX970 ~ 35C
Running Prime95, Blend test 8 cores, temp taken after 5 mins
All cores ~60C
SSD Drives ~ 30C
HDDs ~ 37C
GTX970 ~ 35C
Running Unigine, AAx8, 1920x1200
All cores ~54-55C
GTX970 ~ 79-80C
How ah? GFX not overclocked, only CPU
Unigine is more stressful than gaming leh... Try playing a game for 1 hr non stop and use gpu-z to record ur temps. Then check for max temp.
Gymrat76
Thanks, will try that.. but think no diff.. it was 80C also when I was playing BF3 on Ultra.. think its just the characteristic of the card :D
i1magic
Ambient temp: 28C
Idle:
All cores ~45-46C
SSD Drives ~ 30C
HDDs ~ 35C
GTX970 ~ 35C
All cores ~60C
SSD Drives ~ 30C
HDDs ~ 37C
GTX970 ~ 35C
All cores ~54-55C
GTX970 ~ 79-80C
Thanks for sharing. Would be good if you can post a HW-Monitor picture here. That would allow us to get more info.
ryuxdragonx
A repost here
1. Aircon off
2. Ambient temperature 32 +/- 1ºC
I'm not if these temps are considered ok or cool
Running stock for everything at the moment
Exaita
I need help here ...
Need a solution to cooldown my cpu... the temperature is too high and i dont know what is the problem. Using the stock cooler given.
Edited : found out that my system was set to OC mode, turn it back to normal but temp without still at 50~60 degree....
Alphas
The aida64 screen shot on the 7" monitor
The top fan and side fan have 0 rpm until the CPU reach 50C then they will activate.
Alphas
reapply better thermal paste or change the CPU cooler. I have exactly the same core i5 processor as you.
eciloP
Hi, this is mine during idle. Room temperature was around 30 degrees.
[/URL][/IMG]
After playing DA Inquisition for about 10 minutes, graphics quality in ultra settings.
[/URL][/IMG]
eciloP
Btw some questions regarding chassis fans. How should I place them? Currently I am using deepcool tesseract which has additional 120mm fan mountings 2 each on top of the chassis as well as on the side panel. Currently I also have 2 Cosair quiet edition AF series and 2 quiet edition SP series which were bought from Lazada. Other than placement, what sort of settings should I apply to them i.e. the rpm. At the moment I have placed the AFs at the side whereas the SPs on the top and selected full for the rpm settings.
Exaita
50~60 degree.... on idle or load?
if on idle, reapply thermal paste.
it was on idle.
Just change to a 3rd party heatsink and reapply the thermal paste , now on 39 degree idle and 60 degree on load.
i1magic
This is how I place my fans.
Alphas
The top red fan on the HDD should point left into the casing, and remove the green fan. Not a good idea to have two fans on the front panel facing in opp directions.
i1magic
The reason why I put the green fan there is because the running temperature of the 2 harddisks, drops by about 10 degC. I didn't want the hot air from the harddisk to be used to cool the cpu.
I can add another fan (blue colour) at the top of my casing. Would it help?
Alphas
air flow does not work this way. You are introducing turbulence and canceling the air flow. It is alright to blow from the HDD to CPU, does the HDD temp reach 1000C to affect the CPU?
