[Temperature] CPU & GPU idle & load running temp - Please share here!!
Smartypants
Mine -
Everything on stock, idle temps.
Kinda high huh. Ambient temp is 32 degrees celcius.
12122012
Hi guys,
New to this thread.
Here are my quick details:
CPU: Load 90C
Idle 50C
GPU: Load 80C
Idle 45C
These figures should be ok right? Maybe the CPU is a little on the warm side for load but should not be a problem right? They say max temp is 105C for the i5-2500k.
yes 90c is on the high side... IMO idle ~40c and load ~70c (stock HS, ambient 30c)
i5-2500K Tj. Max is 98°C, which the cores can reach before thermal throttling is activated. The processor shuts itself off in order to prevent permanent damage.
i1magic
Just for sharing
My rig at the side with 2 AIOs.
Idle
CPU oc to 4.4khz, 34-36deg
GPU, 39deg
BF4 load
CPU, 59deg
GPU, 69deg
Intel burn test after 10passes
CPU, 83deg
Ambient temp? In aircon room?
i1magic
Mine -
With stock HSF and the casing you using, the temperature are quite ok.
With normal casing and after market HSF, my cpu temp is about ambient + 8 degC and gfx temp is about ambient + 13degC.
FinalTidus
but should be still safe right?
using CM TX3 as my hsf.
royfrosty
Loaded temps for the pentium g3258 ;) air cooled no aircon. Room ambient 32deg
royfrosty
Ups for only Intel Heatsink Overclocking results of 4.2ghz @ 1.180v.
On Prime95 Small FTT which stresses the FPU and brings the CPU to its max temps.
i1magic
ambient: 30+ degrees
cpu idle: 31-36 degrees (h80i, mx4)
gpu idle: 31-32 degrees
normal surfing + office stuff: 32-38 degrees
under load (game at max setting/ video rendering) cpu: 48-54 degrees
under load (game at max setting/ video rendering) gpu: less than 50 degrees
Never run prime95 as I am using a locked cpu. My com is at the living room where there is no air con.
I would say that this is very good temperature readings.
Godeau
My downloading com after 10mins idle
ambient room temp, no ac
i1magic
JustAnotherTroll
Ambient 29deg+-?
Don't like the idea of my gpu fans not spinning thus enabled the fan control.
No idea why my SSD higher temp than HDD. Even if I swap them around still the same. :(
i1magic
Ambient 29deg+-?
My room temp is also about 29'C, maybe warmer.
Yah, Samsung harddisk runs very cool. See picture below.
Your cpu and gfx card temperature are both very good. If you want the harddisk to run cooler, install new fans to blow at your harddisk.
That is what I did.
Gymrat76
H80i on silent mode (pump & fans)
Ambient temp: 28C
Idle:
All cores ~45-46C
SSD Drives ~ 30C
HDDs ~ 35C
GTX970 ~ 35C
Running Prime95, Blend test 8 cores, temp taken after 5 mins
All cores ~60C
SSD Drives ~ 30C
HDDs ~ 37C
GTX970 ~ 35C
Running Unigine, AAx8, 1920x1200
All cores ~54-55C
GTX970 ~ 79-80C
How ah? GFX not overclocked, only CPU
