[Temperature] CPU & GPU idle & load running temp - Please share here!!
i1magic
Did you run this test in a aircon room or no aircon?
I missed my Samsung HD103SJ. I RMA-ed it but Seagate replace it with their 1TB. When I got it back .... sian half liao.
Which GTX670 are you using? Your running temp is really low.
JustAnotherTroll
no aircon.
asus 670 dcu2.
i feel my temps just average only though..
potato_chips
Hello, my i7 950 runs at 60+ at idle temp, hits 90+ when running bf3 (measured using Realtemp). Is that normal or should I start cleaning my heatsink? Although I do not know how to. Lol. (Thought I cld ask here since its a thread abt temperatures :D ).
dinosau4
90 is high, try HwzMonitor. if it really runs 90 you should prolly do something about it before it's fried. ;)
potato_chips
Took out my heatsink and tried to just dust it away without applying thermal paste, fixed it any temp still around the same. 70+ when idle. lol -_-. time to get my hands on a thermal paste..
i1magic
Clearing the dust on the HSF is really PITA.
I am too lazy to do anything to it for now.
i1magic
my temp at idle, no aircon. compare to all of yours. my one life in suana sia.
Assuming the room temp at about 30degC, you temp are ok.
If you have any browser running .. the temperature will be higher. So the best is to start your PC ... let it run for about 5-10mins and then take the reading.
zjlim86
Is this temp normal? only firefox is running in an non-aircon environment.
ps: how do I post pic?
KiLLeRbOi9
My idle temps with browser and iTunes running in background:
Edit: This is with an OC of 4.8 GHz on my 2600k.
