- Sep 16, 2018
Shortcomings of the eb810v
1) No VLAN (LAN side) support
2) No WireGuard support for VPN
3) The 10G SFP+ WAN (Combo) port cannot be used. Only can use the 10GE WAN(Combo)/LAN ports
4) Does not come with built-in speedtest
5) EHT (upload speed) not realized for 5/6GHz if devices have no 240/320MHz support
6) Cannot configure the WAN port into LAN port
On the consumer router side, Asus probably has the best features. On the other hand, Asus router will usually be more expensive.
For example, top of the line Asus ROG GT-BE98 WiFi 7 router will have the following.
1) VLAN and Guest Networking Pro
2) Wireguard VPN Server/Client
3) No SFP+ port. Only 10G WAN/LAN + 10G LAN.
4) It has built-in OOkla SpeedTest but the CPU is too weak to handle 10Gbps (or 8.2Gbps)
5) Need to wait for testing reports and may need future FW update to support MLO and AFC
6) 10G WAN/LAN + 10G LAN. The 10G WAN/LAN port can be configured as either WAN port or LAN port. But for 10Gbps plan, it will be used as a WAN port.
