TV tuner recommendation
tigerwoods
try tie copper wire , aluminium foil to antenna to make it longer
i think jurong dont have good digital signal
AhChua
TV Tuner PCI
Hi all, can help to recommend tv tuner in pci interface? if possible, would like to get hybrid one to watch all channels. either using antenna or connect to coaxial wall socket... depending on best quality solution.
Appreciate those currently using pci ones give some recommendation.
leadtek DVR3200?
Hauppauge HVR 1300?
Pinnacle hyrid pro?
thank you.
mikengtw
Anyone stay near Yishun Stadium got good signal?:s12::s12:
Hi .. since you want to know I can get the Digital Channel on Yishun here, well here
are some my shot taken using my WinFast PalmTop DTV200H .
And this one is HD5
And here is my hardware..
halocast
channel u got no HD right?
any recommendation for usb de? i looking at avexmedia one
kai_87
Channel U dont have any digital channel nor HD.
Some common ones: avertv volar black hd, avertv hybrid volar hx, WinFast PalmTop DTV200H
des_kong
I bought a USB TV Tuner from Carrefour yesterday...brand name EMTEC S825.
I only able 2 view TVmobile.....after scanning the channel under Singapore....
What abt TV5 and TV8 and channel U?
Can anyone help?
How much it cost? Does it support VISTA?
acewan
hi... I can only get TVMOBILE on my DVB-T tuner... can someone kindly send me the .chl file for totalmedia 3? Thanks thanks!
zhaocai85
Try this model
Kworld 325U
Digital and Analog TV tuner
with AVS input and FM radio
They also come with Cyberlink video editing Softwares
Citiguy
Have to depend on your area. My antenna is not near to any windows yet I can receive all digital channels.
Wah! Can share which area is that kai_85?
BTW, how is the digital signal in Tampines? TIA for replies. :)
