TV tuner recommendation
hermes76
can I ask..
with all these device u guys talked abt here...do u still need to pay for the subscription?
I went to Challenger recently to ask abt a TV Tuner Box, told him i wanted to convert my HD Ready Monitor into a TV which can view HD channels. He told me SG no free-to-air HD channels, all must subscribe so even I buy also cannot view HD ch. Is he b*lls*i***g me?
Challenger dun carrys AverMedia....
seeyourhead_jiejie
can I ask..
sg only got HD5..
tigerwoods
can I ask..
u asked the wrong guy u get the wrong info
tigerwoods
Hello Guys and Gals,
Greetings from AVerMedia! AVerMedia has launched the brand new AVerTV Volar for MAC. It has a classy user friendly software developed by the AVerMedia team, and the best thing is it also supports Windows based systems, so one USB stick for your MAC and Windows systems! Great for laptops, Netbooks, desk tops, CULV platforms, it is a worthy choice.
http://www.avermedia.com/avertv/Product/ProductDetail.aspx?Id=475
AVerTV%20Volar%20M_A815Mac_.pdf
this one the antenna is built-in might not be powerful euff
ERT
To Avertek Contact Person: MICHAEL LEE
Address: 95 KALLANG AVENUE #03-00 AIS INDUSTRIAL BUILDING
Country: SINGAPORE
Tel: 63417839
Fax: 63417739
Please bundle a antenna which can enable Volar HX to receive digital & analogue in high rise HDB flats.
The pathetic puny antenna in HX can't receive DVB-T signals, NOT even TVMobile! & analogue TV signal is CRAP in Bedok.
At S$130, we deserve the enjoyment of clear digital & analogue terrestrial TV signals. And we're not expecting DVD or Bluray clarity standard, just comparable to CRT is good enough.
The A827 itself may be a good DVB-T Hybrid decoder but without a good high power antenna, it is TRASH. And buyers who are unable to receive clear digital & analogue will trash it on forums such as HWZ, resulting no sale of Volar HX for AverTek in Singapore.
Even connecting to wall outlet, Volar HX's analogue TV picture quality is only VCD quality.
Think about it, Avertek.
Regards.
scottie
Country: SINGAPORE
Tel: 63417839
Fax: 63417739
The pathetic puny antenna in HX can't receive DVB-T signals & analogue TV signal is CRAP in Bedok.
Regards.
it's funny that we dont question our govt infrastructure and ask from vendor? the 2-bar antenna hx puts in the pakage is quite good compared to what other brands offer...the single stick one...that is really poor.
the major problem is our digital broadcast towers not strong enough. and analog tv signal from wall point is in standard density format...of course it is VCD quality....
of course..if vendor could provide some solution...it will be the best...but i think real problme lies in gov...
tigerwoods
as the analog signal is vcd quality
is the digital signal consider dvd quality?
scottie
dvd qlty is 720X576 resolution with 25 frames per second.
you can select "Personalize"→"OSD"→"video standard" in the setup of avertv to see the actual signal source standard. it will show 576i and should be dvd standard, at least to our eyes it is, no matter it has been upscaled by the broadcaster or not.
some analog channels also claim to be dvd standard but i really doubt....cuz even our eyes dont believe.
sunsetbay
Moderator
Moderator
i would say both are dvd quality~ as long your hv a good & clean analog signal, the video quality can even surpass digital channel~ analog channels allow u to set upto 10 to 12Mbps video bidrate recording while digital channels are restricted to the amount of bandwidth they squeeze in one freq. eg. digital 5, 8 & CNA share one freq, they hv a relatively lower video bitrate of 3 to 4Mbps video bidrate, resolution at 704 x 576, TVmobile has a same resolution as analog channels at 720 x 576 & hv a higher video & audio bidrate~ :s22:
zzz hq83 zzz
Just bought a AVermedia Volar HX.
Able to receive all the digital channels and HD5 with the antenna that come with it.
XseanX
Hi fellow hwz bro.. need some help..
I just bought a AVermedia DVB-T VOLAR X.... attempt to watch Digital channel on my pc... But I am unable to receive any digital channel signal at all.. even with the bundled high gain antenna.... :(
Should I try to get a better antenna for it? or am I screwed becoz I stay at area that are unable to receive digital channel? Btw I lived ard jurong extension...near jurong point...
Thx in advance...
zzz hq83 zzz
Thx in advance...
place the antenna nearer to the window ?
if not then try a better antenna lor..
during day time, i can receive all the channels with the antenna on my table..
but at night..only can receive HD5 and tvmobile..
need to put the antenna nearer to the window
LxIxVxE
Senior Mentor
Thx in advance...
remember someone use a long copper wire to tie from the tip of the tiny antenna to the metal frame of his windows to boost the signal strength~ :)
u can give it a try~
