think can consider the avertv hybrid super 007 lor~watching only.. best is hybrid.. budget about 100?
if i were 2 get 1 which can record how much price difference would it make?
$70+ only
pci
http://www.avermedia.com/avertv/Product/ProductDetail.aspx?Id=16
any tv tuner with recording software can record already~![]()
yeah~nice.. acts as a fm tuner as well.. i'll get this when i get the moeny.. thx for the reco.. er.. saw it on bizgram pricelist.. is it the avertv super 07 fm hybrid?
normally internal one doesn't come with video antenna, only comes with fm antenna~i think by the time i buy drop to 60 nia.. lol.. jkjk..most probably next mth or so getting now i'm totally broke.. anyway does it come wif an antenna?
yeah, SLT got a lot of antenna~so tat means i haf to get 1 from slt? do slt sell those like 1 string tat type of antenna.. or do the bunny ear de antenna haf a cable for u 2 connect to the card de?
oh ya.. and can the bunny ear de recieve fm as well? or just analog/digital?
a few dollars for a rabbit ears antenna~
or $20~$40+ powered antenna~
u not going to connect to cable point(analog only) or rooftop antenna(analog and digital)~?
usually this will give u best quality~
u bought urs already~?ah. easy. hybrid.. too much thinking.
easiest is the avertv one.
but got to wait for it show.. then will drop to 89 dollar (usual 129 bizgram)
http://www.avermedia.com/avertv/product/ProductDetail.aspx?Id=293
if not cheap cheap hard to find support would be the one below
http://www.dealextreme.com/details.dx/sku.8325
this one got lots of choices sia..
nope.. my room dont haf... only got 1 window.. my old tv use rabbit ear de.. duno is too old liao or wat.. signal not gd de.. same position sometimes gd quality sometimes cant even see anything.. but tat 1 is come wif the tv de...
u bought urs already~?![]()
DIY a tv point in ur room~?![]()
quite a few months didn't go SLT already~live which slt shop would u recommend me 2 buy the antenna at?
no lah~alrite noted.. so it shouldnt cost anything more than 20 correct liao rite?
the route by ur phone soclet into ur room not possible for u to lay a tv cable~?wah diy.. cmi lah.. i ask ppl make 1 wall socket for phone in my room my dad make alot of noise alrdy..
the route by ur phone soclet into ur room not possible for u to lay a tv cable~?![]()
