TV tuner recommendation
anqiang
anyone using AverTV Volar Hybrid HX in AMK area ?
hows the digital quality ??
relaxcatdog
If you receive TVMobile then it is digital tv. there should be on the menu of the setup of wintv to choose to scan digital or analog tv.
your digital reception is bad, then try to adjust your antenna or put closer to the window
Tks for your reply. I managed to receive all the free to air channels. Image quality is quite good. Only cannot receive HD5 as I am using cable connection to my pc.
LxIxVxE
Senior Mentor
can get a video switcher if want to connect both cable and antenna to ur tv tuner~
then can select source a or b(or even c) on the video switcher~
LxIxVxE
Senior Mentor
bizgram got tv tuner offers~ :)
http://www.hardwarezone.com.sg/priceguide/newsview.php?id=3067
Blue.Wing
would like to ask, for those using avermedia hybrid tuner 007? You guys using Totalmedia 3.5?
Is there a freeware software? coz totalmedia 3.5 is a trialware, alto i find it very easy and gd to use.
nsguru
If I buy a powered antenna then I can receive the analog signal better? Will this affect the digital signal?
LxIxVxE
Senior Mentor
uninstall 3.5 and go get the totalmedia 3 from geniatech website~ :)
free one~ :)
edit :
avertv software not good enough meh~? :s11:
it supports h.264 hd out of the box, rite~?
LxIxVxE
Senior Mentor
those signal kind of qns, hard to answer u~
have to try out then will know one~ :(
nobody can guarantee u what can u receive with a powered antenna~
Blue.Wing
free one~ :)
edit :
Avertv software cannot scan properly and it's abit complicated. I cant get clear images for most channel using the original avertv software :S
LxIxVxE
Senior Mentor
so bad ar~?
maybe u didn't configure properly~ :(
yeah, it can be complicated for ppl new to tv tuners since it has more features/functions than the totalmedia~ :)
Blue.Wing
btw live, totalmedia 3 is also from arcsoft as well?? or this software belongs to geniatech?
thx thx :)
audiovideo
Just got the HX version today, installed and everyhting is good. Crisp and clear pic. However my HD5 no sound leh? why ah? :s11:
can I use this for normal TV?
I bought a diayo analogue antenna but not clear many snow...
harky
cool been looking for this quite long
look like AVermedia is a gd deal
may i know which one can record / watch digial and analog in gd quality?? and can receive fm radio also...
for using on laptop
newbaby here na
bluroblur
which TV Tuner is compatible with windows 7 huh? i scare i buy liao cannot watch then waste $$
harky
may i know which model can record / watch digial and analog in gd quality?? and can receive fm radio also...
for using on laptop
