TV tuner recommendation
yhw22
using Win-HVR-900, can view HD5, Digital 5, 8, CNA and TV Mobile. But for HD5, sometimes is laggy. What is the problem? Note using powered antenna.
SPEED
LxIxVxE
got any recommendation for a PCI slot based one?
best if got vista64 drivers support.
thanks
MITMIT
Do you have AverMedia brand USB tuner in SG?
This brand is good, they use their own software (not unstable TotalMedia), which is very stable and low resource consumption. On systems that marginally meet requirements, it performs very well. AverMedia is made in Taiwan not made in China.
www.avermedia.com
AVerMedia is sold in SLS and Challengers tores.
the disitrubutor telephone is avertek 6341-7839
idrinkecoke
if i dont wanna connect to tv point, but uses atenna, any good recommendation?
MITMIT
it takes more cpu resource to decode hd5, so maybe it is the reason of your cpu and memory spec. what is the cpu usage when you see hd5?
mrekoj
use pci better or usb??
not about ease of use (usb confirm wins)
but picture quality or signal ? (will have differences?)
yhw22
100%. if i add RAM, do you think it will help to solve tix problem.
i tested with my laptop with vista os, no problem and very smooth. But when I try to link my laptop to LCD TV using HDMI cable (note: both my laptop n LCD TV got HDMI plug), it just hang after less than one minute of smooth displaying of any digital channels. Anyone know what is the problem? If I connect using VGA cable, it is very smooth.
tigerwoods
just hooted this at Fuwell $68
can receive these channels
signal always at 90+ %, antenna hang on the wall
area is AMK ave4 6th storey
pic quality is excellent
Highly recommended
tigerwoods
AVerTV Volar Black HD
Ch 8 Digital
Ch 5 HD
Tv Mobile Digital
Georgeanna Parnel
A TV tuner card is a computer component that allows television signals to be received by a computer. Most TV tuners also function as video capture cards, allowing them to record television programs onto a hard disk.TV tuners are available in a number of different interfaces: as PCI bus expansion card, PCI Express (PCIe) bus, PCMCIA, Mini PCI Express, PCMCIA Express or USB devices. Ethernet-connected devices also exist (HDHomeRun) and (HAVA). In addition, some video cards double as TV tuners, notably the ATI All-In-Wonder series. External TV tuner card attachments are available for mobile phone handsets like the iPhone, for watching mobile TV, via TV stations on 1seg in Japan (SoftBank), and for soon for the proprietary subscription-based MediaFLO in the U.S. (Qualcomm). There is also a "converter" for watching DVB-H in Europe and elsewhere via WiFi streaming video (PacketVideo).
Cosmetic dentist in Southampton
mikengtw
Highly recommended
Hi ..
Just want to know are u using on your notebook or for your desktop ? Cause I am looking
for one as my desktop just break down already, need to replace one as I am wonder weather
would it work notebook since yours is a AVerTV Volar Black HD.
Thanks.
kai_87
I using usb avermedia volar hybrid hx with the bundle antenna. The analog signals for all channels is super weak and total unwatchable. PC was about a few metres away from windows. Have try shifting the pc and antenna near the windows but signal still weak.
For digital, I can get normal ch 5 and 8 and HD5. Sometimes video was jerky too.
If get the powered antenna, do u think it will work? Where to get a cheap but good powered antenna? Thanks.
