TV tuner recommendation
tigerwoods
Hi ..
Just want to know are u using on your notebook or for your desktop ? Cause I am looking
for one as my desktop just break down already, need to replace one as I am wonder weather
would it work notebook since yours is a AVerTV Volar Black HD.
Thanks.
using on my desktop
tigerwoods
I using usb avermedia volar hybrid hx with the bundle antenna. The analog signals for all channels is super weak and total unwatchable. PC was about a few metres away from windows. Have try shifting the pc and antenna near the windows but signal still weak.
For digital, I can get normal ch 5 and 8 and HD5. Sometimes video was jerky too.
If get the powered antenna, do u think it will work? Where to get a cheap but good powered antenna? Thanks.
a good powered antenna cost $40 -$50, not cheap, i think yur location is the issue not the antenna
try put antenna at diff position, put near the top of open window, point antenna outside window
tigerwoods
my AVerMedia AVerTV Volar Black HD in action
kai_87
So expensive ar. But would a powered antenna help?
Also I currently using TotalMedia 3.5 from ArcSoft. Is it free?
drift01
so good u all can receive digital channels
even using a powered antenna near the window i only can watch TvMobile :(
tigerwoods
powered antenna will help abit
TotalMedia 3.5 is not free , plays well.
TotalMedia 3 is free but dont play well
i use CyberLink PowerCinema to watch HD5, it plays smoother and support 5.1 sound
normal digital channels i just use avertv s/w to watch, not much diff from other s/w
kai_87
CyberLink PowerCinema also not free. Any freeware to recommend?
LxIxVxE
Senior Mentor
u need to try out then will know one~ :(
can go make or buy a extension cable so that antenna is beside windows~
tv cable, not usb extension cable~
can try out those $5+/- rabbits ear antenna too~ :)
juz a V shape kind of antenna~
remember someone using that, claiming to be better than the bundled antenna~
average price of an powered antenna ard $30 at SLT~ :(
renesis88
hi... im living in HDB, 2nd storey
i intend to use antenna, will the signal be poor?
tigerwoods
can try wrapping copper wire or aluminum foil to the antenna to make it longer, maybe can get better reception
tigerwoods
also depends where u stay, ppl stay in single storey hse also can get good reception
renesis88
oic.. i will try that
thank you :)
CoolRock
From their own website, it seems that it doesn't support FM.
