UGREEN 100w charger ..
twosix
Worth buying?
hardly use for laptop.
skip lcd display for lower cost
This one very old liao. Gen1 gan technology. I've this for years already, but it's good. Still working well.
BBClone
I have 3 of them.
It’s great and reliable, comes with the 2m cable.
Only thing is it’s quite long and heavy, so if you’re using it horizontally, with time it can sag down and you have push it in again.
DigDub
This looks slim and portable. Very suitable for travels.
Are both USB C ports 65w?
Yes it's a very portable multi pin gan charger. Comparison with airpods pro 3 case size.
And the pins are retractable, don't have to carry extra adapter pins to swap around for different countries, everything is self contained within.
If using one port is 65w. If use 2 ports, port 1 is 45w and port 2 is 20w.
dev_stg_prd
Gan charger recommendation​
If need to charge 2 cell phones for travel use .Min wattage to get . which model ah?
hwsstx
You need to know how much Watts each of your phone needs, then study the GaN Charger Power distributions if/when 2 phones are charging for whether the Watts are sufficient...
Then you need to study your phone's brand whether it supports Ultra/Fast charging using 3rd party charger, in your case GaN Charger eg OPPO supports VOOC Charging & most GaN Chargers dont support this tech. However latest OPPO also supports Power Delivery tech which is available for some GaN Chargers.
But ignoring what I've said above, I would go for 65W with 2 outputs...why not 100W? because 100W is heavier. So for charging only 2 phones 65W is sufficient.
