UGREEN 100w charger ..
Zinna
Can buy the anker 1 cable split into 2
https://anker.com.sg/products/anker-2-in-1-usb-c-to-usb-c-140w-braided-fast-charging-cable-a8895
Then GAN charger buy anker also. Many different capacity can ownself go search
https://anker.com.sg/collections/wa...ature-control-new-heat-dissipation-tech-a2698
Ask yourself if you need super fast charging. Most phones with 15-25walt charging, if you have 30 mins to charge, can charge a good %. I usually midday go back hotel to do business, then sit sit abit, and phone charged to enough % for the remaining day
Devilsire
if want accurate recommendation, gonna first research on
1) what's max charging Watt each phone
2) what charging protocols supported by the phone eg. specific brand proprietary eg. VOOC, Mi, SFC?
and alot ppl didnt know, GAN tech is just more about the smaller compact build, its the supported charging protocols that really matters aside from the universal PD PPS QC2.0-4.0
dev_stg_prd
You need to know how much Watts each of your phone needs, then study the GaN Charger Power distributions if/when 2 phones are charging for whether the Watts are sufficient...
Then you need to study your phone's brand whether it supports Ultra/Fast charging using 3rd party charger, in your case GaN Charger eg OPPO supports VOOC Charging & most GaN Chargers dont support this tech. However latest OPPO also supports Power Delivery tech which is available for some GaN Chargers.
But ignoring what I've said above, I would go for 65W with 2 outputs...why not 100W? because 100W is heavier. So for charging only 2 phones 65W is sufficient.
So if can’t get ultra fast then get quick charging good enough right. Is gan to get or
lizzykai
Anyone know if can buy the china one then buy the adaptor, shouldn't be a problem right
dev_stg_prd
I need to optimise for Mi and Iphone
Devilsire
So assuming u want optimised with Xiaomi's Mi turbo charging 67-120W and Iphone's PD 40W,
search for Cuktech (previously known as ZMI, a XIaomi's sub brand)
15 140W, 10 mini 120W, 10 Ultra 120W can support charging both phones concurrently at top speed of 90-100W + 30-40W
each around ~$40-50
nom.nom
I just bought this last week at $51, not bad! got display of how fast it's charging and supports major protocols. Can bring for travel too
https://aukey.sg/products/aukey-pa-...art-display-eu-uk-us-th-interchangeable-plugs
SupremeLord
Now for power related charging etc I dun dare to get those OEM brands cheaper options liao, ever since got fire incident that need scdf to come, I now really don't mind spending abit more $20-30 to get a more reliable brand charger with proper safety protection built-in. To protect my family and also to device, don't scrimp on chargers liao.
Like what others have shared I think ugreen anker won't go wrong, avoid those bo brand or cheap but super high wattage ones
Devilsire
what is that household appliance u mentioned? :frown:
SupremeLord
Though it's not a charging device, more of a heat emitting device for shoe drying, it's those quite cheap $10-20 products off shopee Lazada
Point is such products often has poor QC esp OEM products that was design and manufactured for mass selling on platforms
Sunshine82
for travel use, the weight consideration of the charger is very important, especially for those 2 pin plug countries, the plug in can be very loose, and fall off easily if too heavy.
