Vinyl Flooring
chillago
Alamak i know where is the showroom la lol
Just asking if u are using and if you know where its made.
Thanks!
Yes, I used it for my entire flat. That link was intended to show you my review.
The tile is Amstrong brand (USA), made in China.
So far so good.
jerichoo
So far so good.
Thanks bro. Can share why u chose them over evo or flr expert?
Is it just price?
tbs
Any company to recommend for vinyl flooring? Mind sharing contact?
notsotechben
Hi John,
do you suggest doing self-levelling before vinyl overlay for a resale 5rm hdb? the existing floors are tiled. thanks
Moowoow
Can share any risk brushing with asbestos during vinyl flooring process
xeneryx
I have saw an ad using vinyl to overlay bathroom floor and wall.
Wondering if it’s waterproof ? And will I have any problems ?
Kevin10
Ok. Will approach to ask them for quote hehe. Thanks
Best is go down and have a look and listen to what they says. Cos the range are quite big , it seems like got from $2+ per sqft till $6. So better to head down to showroom and understand more. :):)
That time I never look around cos I support my friend , so never go look around much.
johnong316
Hi John,
sorry for late reply. I seldom login here. No need self leveling as long as the floor is even and smooth. Bottom line, whatever subfloor we laid on, the vinyl will follow suit. Vinyl cannot produce magic to make uneven floor even.
johnong316
they are using a material called SPC. Material is waterproof. Installation method is the same as floor. They will glue the planks on the wall and seal up the wall edge using waterproof silicon. the click system prevent water from seeping through the plank joins. The silicon need to be thick so that it wont wear out and crack easily. If there are using a clear silicon, the color will turn yellowish in long run. If they use a colored silicon, having a thick silicon on all edges is unsightly.
Coming back to durability, I cant comment as we dont want to do it. You may wish to check for Xing Floor or Refloor as I know they are doing that.
