Whitestone Dome Screen Protector Problems..
ZaxGax
Went down to casefactorie to apply the zeelot tg just now in the evening. To my surprise, the glass is smooth as baby skin! I noticed that at 1 of the corners, there seems to be some air bubble...but its very tiny (just an eyesore to me). So far my fp is responding well. Just need to press a bit harder when the default sp was on. I also didn't need to re-register my fp.
KYLee
Just installed zeelot at nahm @ tampines. Must say the oleophobic coating is good and FP works well. However it is very slightly slower den it was when I had the samsung original screen protector on. Overall very impressed by the patience and skill of thr guy applying at nahm. Highly recommanded! I'm not affiliated with them at all, just a satisfied customer!
tutonic
How's the fingerprint scanner working? Do you need to press hard or harder than usual? Also, how much is namh co charging for Zeelot eh?
KYLee
Yestertday at the shop it works flawlessly just as per normal. However as of this morning, can tell that its not as good. Need to press slightly harder and longer.. Paid 39.90 for mine
tutonic
That's usually the way it goes. The efficiency usually drops as time goes by. Please check back in a week. If everything solid, then I'll consider making the switch. Haha.
gapboy
at jb those uv glass sp is about 40rm... I did for my s9+. I havent get the time to go jb to check @ KSL again for s10+
KYLee
It will be a pity if it gets worst.. Hopefully it will be better a few days later after the glues dried entirely
shadow84
With the new update, i registered a new FP and it works 90% now. Gonna try delete the existing 3 and recreate 3 more new ones. Still using wsd though.
*EDIT: Deleted all 4x FP and re-registered 2 more. Works 95% liao. Light tap and hold for 1s and screen turn on le. Only thing is that the screen sort of like flashes from AOD/lockscreen to home screen. I think it might be coz i turned off animations. but no big deal for it as long as it works the same as w/o sp. And my touch sensitivity is turned off.
shadow84
i only use 1 x fp registered on both thumbs works since before patch
I have a feeling for my wsd application, the btm half has a bit more glue than the top. As long as it works fine, good liao.
KYLee
SELF-UPDATE on zeelot sp day 1.. After the update last night, removed and added new finger print and now it works as good as before!(or as good as with original Samsung SP)
trenzterra
Yeah zeelot seems to be quite reliable 4 days on. Definitely better than whitestone. Don't believe the "second batch" bs.
Ye_Rongtian
I have been using zeelot since 4 weeks ago. No problem from the start. Only problem is the edge glue came off but that is my fault for being finger itchy when I peel off a small strip of glue off.
xenocide
got 1 UV glue SP from Lazada @$15
Claim to work with finger print scanner but it does not work at all!
Shop name is Luowan.
But the TG quality is good. very smooth and decent oleophobic coating
just a pity the FP doesnt work.
going back to film base
tutonic
I'll go try install Zeelot today at Tampines Mall. Later if got problems, I can start a new thread Zeelot Screen Protector Problems like how I started this one.
Hahaha.
wwh5210
Has Whitestone makes any announcement on the fingerprint issue? Does the same thing happen after the latest OTA update?
tutonic
Just got (and updated) the urgent security patch relating to Fingerprint scanner, 6.9mb in size.
FP scanner seems a lot quicker and more responsive. I've unlocked/locked like 20 times liao, over the last 5 minutes to see if got difference. Haha.
Crappie1318
I also recommend this.. Almost same feeling is original Samsung flim..
Sent from Samsung SM-G973F using GAGT
