bellick
Just received my sabbat e12..
fwah.. much better than the mifo o5 pro and galaxy buds. The bass is damn solid
cloud0
Is there a way to manually turn it off? Or auto power off if no sound signal for a certain minutes? Does the LED light blink even when there's music playing?
The Klipsch Connect App has not been released. So no way to make changes for now
DigDub
I see the user manual mentioned press 3 seconds for power on. But I guess press 3 seconds to power off not possible as it will just adjust the volume?
cloud0
Yup, you are right. Long press is to increase or decrease the volume.
musicsg_com
Would like to swap to this from the rha trueconnect, was thinking if you know is the t5 case smaller than the rha?
Yes T5 case is smaller than RHA.
The earbuds cannot be turned off manually. It will remain on as long as it is connected to a smartphone. If no connection is found, then it will be immediately ready for pairing. After few minutes without pairing, it will auto power-off. Press and hold both earbuds to power on again.
Long-press the earbuds will reset the earbuds followed by powering off, which requires you to re-pair again. The LED will blink when operating.
DigDub
Thanks for the info.
SuperDecker
Yeah I'm very satisfied with the Sabbat E12. I bought the Nuarl NT01AX for 3x the price and I don't think its worth the premium...
Saw some reviews pitting Sabbat E12 and Mifo O5 and they prefer the Sabbat.
davidwong
Bro can listen with your E12 to the tune in the above YouTube @6:39 and @9:00
See is it good listening for those 2 songs?
Thanks deciding between e12 / O5 / earfun oluv and creative outlier gold
winorlose
Ordered the mifo o5 and arrived today. Really nice buds! The construction is solid both casing and buds. SQ wise, more bass.. Will play around with more eq settings to suit my ears
winorlose
The fit is damn solid..like wont even fall off if if i do sprints on the spot
Seriously more solid than the xmini i had
gong318
Tempted to get the mifo o5 for purely exercising and running. Will these fall out? Any recommendation for standard or pro edition?
have been running with it, no issues at all. The seal is great
Sent from Google PIXEL 2 XL using GAGT
