Remless
tried reset network on mobile.
seems ok...
tsank 9
You will be factory resetting every time issues surface. Maybe u want to read the manual and memorize how to factory reset.
If you do not pair it to multiple devices and switches devices often, you will encounter much lesser problems with connection. It performs much more stable if its paired to only 1 device.
Remless
ZhugeLiang 諸葛亮;126448590 said:
Hello. Looking for a budget earbud for normal and running usage. Budget about below 70 would be ideal.
fiil t1x seems to be popular here. Any other recommendation?
Does fiil t1x have bad video audio sync delay?
Thanks in advance.
For sports, it depends if you need aids like ear wings/hooks to stabilize. Havit G1 pro is another sports oriented earpiece within your budget.
Its quite challenging to get t1x under $70 now.
As for video/audio sync, none. It has low latency mode (turned on via app) to even make it suitable for gaming.
https://www.scarbir.com/tws/fiil-t1x-review
Crayon Shinchan
thanks replying. idm topping abit for t1x if it is really that good. :)
thats good. heard video audio sync is not that bad too.
ya i see now cheapest is taobao 299RMD(~62sgd) excluding shipping
https://detail.tmall.com/item.htm?spm=a1z0d.6639537.1997196601.4.e03b7484lOqXu8&id=600158487678
while lazada ~$71 (after first time user code, with 6 months local warranty somemore)
https://www.lazada.sg/products/fiil...o42.searchlist.list.3.56f32107s6DQDS&search=1
Remless
I'll recommend getting from lazada. Taobao shipping takes very long.
From what the bros here who bought from this lazada seller, he uses courier which is ultra fast in delivery.
Nice u still can use new user code(I am an old timer in all these shopping platform that I can never get such coupons already.....:slant:)
Crayon Shinchan
ya. that extra few bucks should be worth it given the delivery and local warranty.
so for that price point. T1x seems to be the best choice uh?
Remless
That's the main consensus from those who used it.
gong318
have lypertek tevi currently, ordered both fiil t1x and mifo o7 to play :)
Sent from OnePlus GM1910 using GAGT
Remless
There's another new one that u might like too.
https://www.scarbir.com/tws/soundpeats-trueshift-2-review
https://www.aliexpress.com/item/4000712393466.html
Very powerful charging case. I almost wanted to buy and try, but decided not to get another soundpeats and to buy from another brand to play with.
Crayon Shinchan
xxSaDanxx
Thx for sharing! Was comparing this between Fiil T1X. Ordered the T1X as more people recommended.
Reasons for liking the SoundPEATS Trueshift 2 it’s because of IPX 7, and I sweat alot. The price is also lower compared to T1X (~$25 different)
Incase anyone interested, can ordered directly from
SoundPEATS Shopee/ Lazada store below.
https://shopee.sg/product/169878610/4317862167?v=f7d&smtt=0.0.3
https://s.lazada.sg/s.lD2s
kazuki666
Alex. You reeveievd your T4 liao mah? I ordered on Sunday, seem pending at customs but didn't indicate which country's customs...
Sent from Xiaomi POCOPHONE F1 using GAGT
Alexz_Hong
haha. my tracking just says "Hand over to airline". That was on 3rd April. mine close to 3 weeks liao? Ordered on 29th March. :s13: Aliexpress did say the estimate was 14-24 days. Not sure if that is factoring in the covid situation or not. Hopefully yours faster than mine.
EmPtYsOuLz
i love the part that it's very compact.
Got mine too, quite surprised by the sound quality
Vocals sound very nice and crisp although the bass sounds a little muddy in busy passages
Now wondering if I should still go for the MTW2
Gadgetfreakloh
But the price so much difference! Truedot are very value for their price. Both I have n true opinion.
xxSaDanxx
My FIIL T1X arrived today. Ordered late night on last Thursday from local seller with 6 mths warranty and free shipping.
Decided on this pair After reading review by @Remless and recommendation by @ksksksls. It’s my first pair of TWS, and my nobbie sharing below.
Pro:
> Fit my ears perfectly. I got big ears and normally use the biggest bud. For this just using the default bud and wing, and all is good.
> Easy pairing. Follow the instructions and all is good.
Con:
> No indication for case charging, to know if it’s fully charged.
> Troublesome if you like to ‘share’ this across various devices. Need to off the TWS, disconnect from previous device and pair to new device.
I’m sharing this with my iPhone and Samsung tablet. For both I d/l the FIIL+ app, and able to do settings there.
Do not is it’s necessary, but not doing the burn in using the app.
Overall, will say it’s worth the price paid.
Crayon Shinchan
Pro:
Con:
Ordered from the same person.
How's the sound quality so far?
Any video audio lag on youtube or Netflix?
Sent from
东汉末年至三国时期(刘备→刘禅) using GAGT
xxSaDanxx
Sent from
I’m not a sound person so judgement may not be off. Haha
It’s good enough for me.
I turn on the low latency via the apps. For far Netflix for iPhone and tablet no lag.
Remless
Note that 90% of the tws in the market work this way, unless it has multipoint. Even if it has multipoint, the max no. of devices u can connect at the same time is 2.
For me, I also share this across many more devices. Just turn off bluetooth on the previous device to connect to another for fast switch. There is never a need to 'turn off' the tws. It goes into pairing mode when the connection from the previous device is broken.
