kazuki666
Does this mean I am receiving soon? :(
Sent from Xiaomi POCOPHONE F1 using GAGT
davidwong
Yo bro how to do both master in iphone? Some clipping sometimes due to slave / master I think
ZhugeLiang 諸葛亮;126677039 said:
For fiil t1x. Both can be master and use as individual.
Sent from
东汉末年至三国时期(刘备?刘禅) using GAGT
Alexz_Hong
do share your thoughts once you get it. haha. i've seen some feedback say sounds similar or slightly worse than T5 only. If so, should be pretty decent, plus have the app support too. :s13: At this point I'm not really expecting to receive mine anymore haha. Just waiting till the indicated time to file a dispute for refund.
TakKiu
Anyone knows how to update the te-01g with the aviot up app? Was afraid that ill brick the earbuds since theres no english instructions.
The app says only for this model? Can you connect to the app?
*Edit Aviot website says the app is only for the model te-01g.
:spin:
Cheese Steak
Finally updated my te-d01g, using the aviot up app. Had to borrow an android phone. Worth the update, finally able to eq and use english prompts.
Cheese Steak
But the app quite unstable, can’t work at times. The eq and changing of control function is worth it.
Crayon Shinchan
I mean both earbud can be use as standalone.
Just put the other earbud back to the case and use one of it.
It works as well
Sent from
东汉末年至三国时期(刘备→刘禅) using GAGT
DigDub
https://www.lazada.sg/products/blackdot-pro-wireless-earbuds-with-7-hrs-music-high-bass-high-audio-quality-one-touch-control-ipx6-waterproof-i577142764.html
Does anyone here have positive experiences with “Blackdot”? seems to be a local brand.
I am thinking of buying this to replace my QCY T5.
Mainly to use during my runs and also these days, Skype calls since i am WFH. :D
Don't waste your money. I bought a similar one known as kucipa t1 tws. Outside they put one nice box, but open up inside is another generic box. I suspect the one you listed is also the same. They just import some low quality generic tws and put the original box inside a nice looking box and sell it at a higher price. Sound quality is like turd and fit is terrible.
davidwong
Congrats! Welcome to the family.
May I know for users who are on T1x what’s the EQ are you all using?
Also do you all suffer occasional clipping (master/ slave).
Also for ios how to pair 2 master?
My fiil t1x delivering today !
Sent from Google PIXEL 2 XL using GAGT
happily1986
Thanks for the reply. I will probably scour Scarbir‘s list for another noteworthy model to buy.
Crayon Shinchan
I using bass option in EQ
Sent from
Remless
Falling in.
I mainly use original, treble (for tv shows when I need the clarity), rock and home theatre.
I don't encounter clippings so far. I mainly use android devices and not sure how ios does it.
Remless
been eyeing this on taobao for a few weeks already.. QCC5124 chip, 10mm dynamic drivers, ANC. might pull the trigger soon
https://detail.tmall.com/item.htm?s...d=615225595484&sku_properties=5919063:6536025
https://www.qualcomm.com/products/features/truewireless
QCC5124 still uses tws+, not the twm. Qualcomm is phasing out tws+ since it has poor user experiences during swapping/pairing. Not advisable to buy tws+ devices now unless you cannot wait for twm. (which should be coming soon)
gong318
ZhugeLiang 諸葛亮;126704589 said:
lypertek tevi bought at $99: enhanced highs and mids without fatigue. Chinese music god
mifo o7 bought at $95: neutral, borderline flat. probably the least separation out of the three,but still enjoyable listening experience
fiil t1x bought at $59: most dynamic and V sounding, significantly more bass compared to the rest, the thump and rumble is more present. That is not to say that the bass masks the vocals and highs as these two are still very much present. Honestly I enjoy the sound on this pair the most but it can get fatiguing.
Depends on your choice of music, ymmv:
-lypertek tevi is really good when listening to ballads/Chinese music, non fatiguing despite the enhanced highs and mids
-fiil is really nice when listening to hip hop and pop albeit it is best for a short listen because it is fatiguing
-mifo o7 is good in general and caters to all music. It is non fatiguing and good for a long listening session while commuting
Personally I'm keeping the mifo o7 because:
1. After using lypertek tevi for close to 5 months, I realise it has issues with the Bluetooth. Once in a while it will pop and distort and the pairing time is a little slow. the Bluetooth range is weak too. Using ur phone to control volume has a bit of issue as well, so u need to use the control the earbud itself to adjust the volume. Overall not a big issue, probably my OCD kicking up.
2. The fiil t1x that I received has issues with the connection where once in a while sound will not play when it is removed from the case until I reconnect/up the volume. The charging pins on the case has a slight issue as well. The button placements on the fiil t1x are confusing and not instinctive and is not reliable as well.
3. The small case and build on the mifo. Touch controls are the best out of the three too, instinctive and reliable. mifo has the most consistent Bluetooth pairing and connection for me too.
4. I generally listen to my earbuds while commuting and listen for at least 1-2 hours so a non fatiguing pair is appreciated.
All these are just my opinions and two cents so don't treat my words as a encyclopedia :)
Sent from OnePlus GM1910 using GAGT
