Hardcor?
- Oct 5, 2013
Any bought Sineoji PT331V ?
I test the response very fast almost no lag.
I suggest you call EasyN Singapore. Lagging or no lagging depends more on the network speed.
You bought? Can give more details as in viewing over LAN WIFI or 3G? Whats the bitrate, resolution? Which ISP? Which area?
I bought one when I bought four HL119EP homeplugs.
Didn't open it yet though.
Bro....u really into camera!
Faster open and give some comments......thought of buying one to try.
Is this suppose to be a Korean brand? Have not heard of this only recently. But the webpage states 2012 copyright.
Korean wordings only I think.
But I tested it at changeller funan on a iPad mini demo.
Image response very fast on wifi image to me good...need expert here to review first.
Why I say fast because I compare to another 2 brands side by side.
Dr_ARCHER, I thought you would have purchased the KIMCHI brand Homeplugs to try?
You mean it's not from Korea but it's printed with Korean words? How strange. Then the actual product is manufactured by Wanscam and not in Korea? Any Sineoji staff here? I would like to know if this is true.
Hi All,
Anyone facing issues with Aztech WIPC401 IP Camera on Asus RT-AC68U router on the following firmware version?
.205 - no issue, can be access outside via http://wipcxxxx.nwsvr.com/
.339 - cannot access via http://wipcxxxx.nwsvr.com/ but can access via external ip address 124.197.xx.xxx:8081
.371 - both cannot access either DDNS or external ip address
Port forwarding is set as usual. What else did I miss? I am using manufacturer's DDNS.
Please advise. Thanks
I do know some service provider's router having problem with portforwarding. But this is new. Did you revert back to ver.205 to make sure its due to software version?
