Xiaomi Box Android TV Box
asriznet
Hi there anyone got idea why my mibox screen suddenly shrink? Initially it was ok then today suddenly shrink....
Could be 2 reasons:
- Your TV screen setting
- Mi Box "Sound & Display" -> "Scale and position" setting
high likely is the 2nd one....
Clarence80
Yeah same, around 3 weeks to reach.
Delivered by Singpost registered mail when reach Singapore.
bro, you're right, it indeed came in 1GB ram when it came, did a quick check with official mi china website, theirs is also 1GB version now.
puzzling:s11:
asriznet
Xiaomi is already coming up with a new version of the mi box? Mini Mi Box?
小米小盒子 - 小米手机官网
With only a HDMI connection, doubt this will be popular for most users unless it's super cheap.
no USB, no OTG, no Ethernet, no SD card, no 3.5mm audio jack.
only good thing i see is, it's super small + built-in bluetooth but the features removed put me off totally.
galliano
å°*ç±³å°*ç›’å** ï¼* å°*米手机官网
Honestly speaking if the 1Gb ram and slightly lower specs will run XBMC smoothly ... why not? SGD40+ android streaming box tht is super portable. Nuff said. I want one
Xterminater
I got my mibox pro/enhanced version that was jailbroken and it has many apps on there including youku XL but I cannot watch any TVB or English dramas in the US. Is the only way to watch it is to set up a VPN paid account? Is there any way to either crack the youku app itself, or find a complete free vpn, not the trial ones? Please help.
Blindaim
gwennliu
I recently switch to use Amazon FireTV. And it is great. The reason is, I can have Netflix, Hulu, Amazon Prime TV, Youtube, Vimeo, Shafa Desktop, PPTV, Youku, Shohu, LeTV, 光芒体育,小豆直播, CloudTV, etc etc all IN ONE SINGLE BOX. In addition, can play excellent Games too. hahaha
Mini Liew: Amazon FireTV Is The Best
thinking of getting one.
what does it offer over the Amazon FireTV?
(or does this allow me to finally cut my StarHub TV subscription?)
kons45
Hi all,
I've just received the MiBox 3 from Lazada (Usb port behind no Lan port) and I have been reading up and trying to figure out how to convert the text from Chinese to English.
I don't speak a word of chinese and I have seen some links but the apk links at those sites are dead.
Please do help me and I will also need to sideload apps.
Thank you
asugama
Guys, last time I have installed a remote app for Mibox which you can cast your TV screen to your Android phone and you can touch on your phone screen to fill up textbox, browse site, etc.
I have tried installed the last Mibox Remote version 4, but this new one doesn't have the feature to duplicate the screen anymore. Anyone can recommend a good remote app to control your Mibox?
Many Thanks
Ultimate Chicken
Arg.
Mibox 3, apparently had a UI update before I can get to it, and now I cannot even find the way to go into the default Android Settings. The option is GONE from the mi store!
The Android Settings was the only lead I had to getting the UI in english.
Now what do I do? Paperweight? >_<'
asriznet
Many Thanks
I use the remote app that shows up in Shafa launcher, sorry dunno how to say name as I cannot read Chinese but it works as you mentioned.
Arg.
Hi all,
Thank you
Follow the steps on here for English UI: Mi Box English UI Replacement & How to Install Apps on MiBox. - Powered by Discuz!
You just need XH Home launcher to change to English, the other apk are not necessary.
nutz1943
Need some advice. My box comes with native installation (no jailbreak or root or any other apps) and no other accessories.
Everything is in chinese now. Can I confirm "rooting" is only for those who need access to english lang?
Also I installed 电视必备 (accept to install 3rd party app). And from there, installed 沙发管家. Anything I am missing?
Do I need to get a micro sd card and also micro usb cable or OTG cable? I found that I do not have any cable that can connect to the micro usb port on Xiaomi box.
asriznet
Root not necessary to change to English, refer to link on my previous post.
