Xiaomi Box Android TV Box
rerear
Pengsp, looks good thanks for the tips.
Anyone recently dianshimao all the shows cannot watch liao? Startup screen all the artwork, cover-art gone.
RoiiPan
Help needed ..
Dear guys .. I brought a Xiaomi TV Box 3 , Chinese Version .
OS Version 1373 ..
I am totally lost because the box cannot watch TV or do browsing ..
Yo i need some help of what I can do ..
For example if i don't modify , how can i load APP to the box .
If I modify it , whats are the step ..
Thanks Many..
oho
Can someone please advise. I have the toggle app, but whenever I open it, it prompt me to update and install, but I am still unable to use, and it kept asking me to update and install. Please help
The irritating thing about Toggle on MiBox is that once they update (and they have been updating very frequently recently) the software, the old version cannot play anymore.
The version is now 3.0.6; you have to search for the latest version of apk on the web (if you do not have playstore installed) and do the update.
Try this
http://m.1mobile.com/sg.mediacorp.android.html
It requires you to install the 1mobile app 1st, then when inside, search for toggle, uninstall yr old version and then install the ver 3.0.6 from them. But in about maybe 10 days you have to search again when again toggle updates!!
I just tried the above. It can work
w3iw3n
guys, i am trying to get xbmc into my xiaomi box. researched slightly and there were some older thread that says i need to connect the xiaomibox to pc and use snappea.
is it still the right way now? I am on the quad core box that is jailbroken.
Pengsp
redname
Been trying to get my box to connect to play store but failed.
Been searching and trying different steps but just cant connect.
Any help?
galliano
Any help?
I gave up after trying on 2 separate occasions.
Looking back I dun really miss NOT having the Google support considering Shafa apps market has most of what I using now.
redname
How abt youtube?
Then how u watch those shows in youku?
Keeps saying its for china
yhw22
The HDMI cable in the xiaomi TV box package is good enough? Necessary to buy a better one?
It is of poor quality. It got lines when connected using provided HDMI cable, so used mine and quality is back to normal. :D
It will also depend on it too. :s13:
redname
mine seems fine, maybe moi TV lousy
Ramelec
My Xiaomi TV Box firmware was automatically upgraded to the official one. Now I like to jailbreak it - is there a link or information how to jailbreak it.
redname
Wat version?
Think latest still no one JB yet
lavive_gp
OS Version 1373 ..
Thanks Many..
Hi,
There are plenty of guides in internet so I won't explain it in details.
Basically you use .apk files you store in a USB pendrive and then after you plug it in the box you install them, the xiaomi box allows such install from USB. There's first a so-called pojie (jailbreak) package to install then ShaFa market.
Seriously, all resources are in internet, just need to follow the step-by-step guides.
enjoy.
lavive_gp
Gosh! :eek: how did this happen? there's nothing 100% automatic, you might have accepted it when it proposed you.
:flash: Be careful not to upgrade your firmware once everything has been installed/configured!
lavive_gp
Their HDMI cable looks OK to me,
but what I faced was that my old TV's HDMI port was somehow a bit rusty (Singapore's weather altered the contacts layer) and then using an electrical contact cleaner (spray) with some rubbing it all became OK (no more lines and interferences on the screen).
