Xiaomi Box Android TV Box
alxneo75
Hi guys, my mi box recently cannot connect to wifi.....
It's 3rd gen MDZ-09-AA....
Tried factory reset n got stuck at detecting wifi but no wifi detected.....
Any help...
Thks.....
junjunjun
Any help...
Thks.....
Try to use a rj46 adapter and use Ethernet cable to connect, after you got connection already then remove the cable and check for WiFi connection
alxneo75
Thks for d fast reply.....
Can u direct me where to get rj45 adaptor....
I see a lot of them not compatible with xiaomi box.....
koroshiya8
Just got the box 2 days.. ago.. very solid.. can do DLNA, i can throw away my ACRyan old box liao..
now trying to find out how to install to USB.. that option like disabled.
Ultimate Chicken
Hi,
Unfortunately I'm the go-to guy for rooting these things from family, who always manage to get these things unrooted. >_<
Anyway, 1.3.87. The old method I use ("miboxIII root" in chinese characters) I used back in Jan thereabouts, doesn't seem to work anymore; it worked when the version was still 1.3.7x.
Now all it does is install SuperSU; When you try to run it it tells you the binary doesn't exist.
This means I can't proceed with installing Google Play.
Any help? Updated version of that batch file?
yhw22
redname
Hi,
lastest firmware haven't JB yet
redname
anyone can teach how to view the shows in youku?
got some shows can be showed in china only.
i tried some VPNs and proxies but they cant be used for the youku app which has HD
Ramelec
Hi,
There are plenty of guides in internet so I won't explain it in details.
Basically you use .apk files you store in a USB pendrive and then after you plug it in the box you install them, the xiaomi box allows such install from USB. There's first a so-called pojie (jailbreak) package to install then ShaFa market.
Seriously, all resources are in internet, just need to follow the step-by-step guides.
enjoy.
Do you have the link to the new .apk files? Thanks
jcbcorp
HDPtv. its an app that shows live tv. nat geo, discovery, axn, star world, fox, hbo, fx, afc, history, got all these and more. but idk if all can play smoothly. too many channels, didnt try 1 by 1. :s13:
there's fei cui, sports and global news channels in the app too
not sure was it just me, most of the channel mentioned above cannot be watched other than afc...omg any got other tested/ workable apk recommendation (excl kodi) to watch cartoon network/ xd, afc, nat geo, discovery, tlc, history, etc....
gregory_choo
Try mobdro, stable stream but in SD only
can watch cartoon network, afc, nat geo, discovery, tlc, history, etc....
http://www.mediafire.com/download/q0ghqxli0o7kl33/Mobdro_1.2.428_Freemium.apk
HDPTv's picture quality is better, but the channel list is not stable, keep changing
oprahsbs
Guys can i check which provider that have this kind of on demand movie?
Checked cloudtv, seems they dont have any on demand movie.
I believe there will be subscription fee.
TIA! :D
Pengsp
Hi,
Try this if you can read Chinese
小米盒子 1.3.87 root
http://www.shitourom.com/thread-1636-1-1.html
http://root.360.cn/
