Xiaomi Box Android TV Box
tckrto
Thanks. Airplay functionality doesn't work. Is there any way I can the box to always detect my iPad?
At the moment no way to get it working unless your on xiaomi beta testing team.
However the miracast for android is working.
saltyman
anyone know why mibox usb cannot be detected by computer?
i downloaded snappea,but still can't detect
vengence_angels
galliano
Spent the wkend with my friend's Xiaomi MiBox (4k ver) which is the latest. He brought it back from China.
Anyway, here's my thoughts and experiences on the MiBox:
Why would you get a MiBox?
Honestly speaking, comparing the MiBox to other Android boxes such as the Minix. I personally do not see the hype.
1. Its OS is locked. I have better flexibility with a standard clean Android box. You can actually root the Xiaomi Box. Somebody posted here the exact instructions but its mostly in Chinese. Please check earlier posts. Without rooting, you can still install apps. I wanted XBMC as my main objective and it worked beautifully.
Since i did not root, i think anything that required Google Play Store is restricted such as YouTube. There are alternatives ... please check link below for tons of good info.
(http://forums.hardwarezone.com.sg/e...-lip-lai-no-sale-no-illegale-apk-4705144.html)
2. Despite its 4K capabilities, i see no need for it. I do not have a 4K TV, and more importantly content.
3. I do not find ICNTV interesting as my XBMC suffice my needs.
How to install apps?
Install Snappea on your PC (SnapPea | Your Android, in Windows) and connect to MiBox via USB cable. Transfer your apks (which you should have already downloaded) to the MiBox. Done.
Getting an English menu/interface?
Install TuZi 兔子桌面 (?????????APP????-???? ????) via Snappea
To make the Tuzi as default launcher
1. Power off the Mibox (turn off main power switch)
2. Hold down "Home" + "Menu" button, and power on the switch
3. Menu appears, choose to reboot
4. A menu appears, and ignore the RECENT version. Choose the other one.
5. The box restarts and a launcher prompt will appear. Choose Tuzi & the option "Always"
I think there may be an easier way. But the above worked for me.
Hope my blurry pics do help those who need guided help.
galliano
Hahaha.. I think my last post just saved you some $$$ from all that extra add-ons (eg, XBMC, English Launcher) if u still have intentions to buy a MiBox from the local dealers.
vengence_angels
definitely some money saved..
did ur friend use a VPN to watch programs?..
i am thinking of watch HK drama (my wife actually).. and BPL only..
tak
my xiaomi box cannot connect with my PC (windows 8.1) i using the usb cable to plug into the mirco usb port. I reset to factory default setting. Can anyone help me?
galliano
No.
1. Based on earlier posts in this thread there is a loophole for free vpn if you need to watch the ICNTV progs.
2. Go to the other thread about XBMC. There's tons of info about using it to watch HK/Korean dram (using AZDRAMA repo) and BPL (using p2p stream repo) http://forums.hardwarezone.com.sg/home-theatre-audiophiles-13/xbmc-live-tv-4660818.html
tckrto
No.
Btw the solution only tested on mibox enhanced/pro/4k. Actually nothing fantastic on mibox except for the price but sadly those people bringing it in mark up too much already.
vengence_angels
gregory_choo
tak
when i reset to factory default and connect to my windows 8.1, the following was shown on my computer screen,
The last USB device you connected on this computer malfunctioned and windows does not recognized it!
