Xiaomi Box Android TV Box
FreewayJet
Any recommendations to get the xiaomi 2nd or 3rd gen? Intend to install xmbc, display resolution is 1920 x 1080p. Thanks!
tckrto
Read the tutorial already but did not find the VPN option in XiaoMi 4K in tne setting menu.
The vpn setting have to enter via xiaomi 应用市场. If u still no sure later i go take pic show u.
tckrto
The rest just follow FLYVPN tutorial.
S750WP
The free VPN is super laggy can't use it continuously. Only use it to bypass the IP check nia.
But lucky found this loophole :s42:
The 广电列序号 displayed after use with free VPN but the movie play back very lag and when I checked the ethernet connection it says icn认证失败. I think still need a pay vpm in order to play smoothly.
gregory_choo
Icntv is not the only way to watch movies, there are many other apks with smooth streaming, don't have to use VPN.
kottty
anyone know how to use lan over WIFI on mibox 3?it keep connect on WIFI .can't find any setting to choose lan network
tckrto
BarneyMedic
Hey guys, interested to buy this mibox. Buy local or buy from taobao better? Also, izzit preloaded with english so that I just go to settings and change language? Thanks
tckrto
Preloaded with english means install tuzi launcher or some other launcher that have english lor.
This mibox is no diff from handphone. If u know how to play handphone then any android box also can play.
kelvin03
Hi guys, I'm using the enhanced version (4k) and my firmware is showing 1.3.44. I understand there is a update to version 1.3.51 but it is not showing up when I check for updates.
Any way to resolve it or how to perform a manual update?
tckrto
I thinl the update only apply to the normal box. Enhance/pro/4k versio still in 1.3.44
S750WP
The reason I buy the Mibox is for ICNTV, I can watch movies using android apk using bluestack on PC.
I subscribe 1 month VPN service for USD5, going to try Netflix free trial for 1 month also, and witn paid VPN tested on Mibox CNTV can stream smoothly.
valueair
Agreed, just imagine you have a very big 32", 42" or 47" Android tablet on your TV console :)
