Xiaomi Mi Max - Part 2
kelvinti
I use the default miui calendar. Tried google but don't like. I like samsung calendar though, but so far not able to find a "cloned" version of it.
Anyway I don't usually store reminders to calendar, so still ok for me using the default miui one.
Opps! I blur King..
Now that you have mentioned it. I'm actually using the MIUI default calender and not Google calender.. lol....
pokipoki08
For those who bought export sets, if u want to be rid of miui, bloat ware, or firmwares making profits out of you, lineage ROMs from XDA is a good choice.
For the security conscious, AFwall+ or xPrivacy (xposed) is a must.
To extend & scale higher battery backup, totally disable Google Play Services but retain all Google Apps functionality by using microG.
Custom kernel with Interactive CPU governor, properly calibrated, will make phone smoother & enhance battery performance.
ARISE sound mod juz make the phone sound better than it should. Enjoy.
Need unlocked bootloader & rooted phone.
cokiee
Welcome, bro! :)
Reporting in with what kind or version of MIUI? Kekeke.
I have been using Google Calendar. Nothing else beats it. :)
business calendar pro, since 2011.
Tried many
Solcalendar is the best
Thanks you guys! I'll try out solcalendar and business calendar.
@kelvinti: 8.2.10 lo?
@dragonguy - I agree! Used to be on samsung some moons ago, and I like theirs too. You could just update the widget instead of having to go into the main calendar app after tapping on the widget.
cokiee
Not courageous enough to unlock bootloader and root, but I did realise - coming from a mi3 - that google REALLY has a lot of preinstalled stuff now!
weiiix
Hi, anyone got this issue? Headphone jack loose or came off.
This morning when i try to plug in my earphone, it cant be push in fully and no earphone is detected.
Lucky still under warranty.
Sidler
Who u buy from?
Shib
Does that mean ads free?
Jimmyf86
Hi Guys,
just got my Xiaomi Max yesterday. Pls advise if this is the latest version of the phone;
Android Version: 6.0.1 MMB29M
Android Security patch level: 2016-11-11
MIUI Ver: MIUI Global 8.2 | stable 8.2.12.0.0 (MBCMIDG)
CPU: Hexa Core Max 1.8GHZ
Baseband Version: A.2.1.c4-00011-0829_1832_28e71bf
Sidler
Hi Guys,
Fake rom.
Real ROM only have 4 numbers. Those with 5 numbers are fake.
Current latest for global stable is is 8.2.1.0
You need to flash with miflash to go to Xiaomi ROM.
1982-1994
eh how to convert developer ROM to china stable ROM?
my pc failed to detect the COM port. sibeh sian.
touchme
mentioned was screen recorder on latest ROM, where to find/activate app?
Audiology93
Hi Guys,
You have a modified/fake rom. Should have more than 4 digits in the MIUI version. Where did you get it from? You'll need to flash official global rom 8.2.3.0.
Sent from Xiaomi REDMI NOTE 4 MTK using GAGT
kelvinti
Folks on official Global rom 8.2.1.0 / 8.2.3.0.
Is the My Transport app can be downloaded via Playstore already? :s11:
I ask because I'm not running the official Global rom.. I can't test it at the moment.
