Xiaomi Mi Max - Part 2
krazyhippo
OK. 32 variant only...
Can check if the auto brightness works properly especially so after you switch off the auto brightness that the brightness level returns to the preset manual level fast and correctly?
I only can say the auto brightness react accordingly to the lighting. It dims down automatically, brighten up accordingly too.
i1magic
Serious? I just sold mine at $180, with the buyer self collect at my place. Guess I'm lucky.
$180 should be snap up quite quickly by people right? How long did it take from you posted it for sale till you transact?
What was the price you posted?
kelvinti
I see. Let's say your manual brightness level is set at 30%.
So, when you switch off the auto brightness. Does the level returned to 30% each and every time?
kelvinti
U mean to say Mi Max is better for games than Mi Max 2? :eek:
Yes. 650/652 performs better in graphics than 625.
I have got to agree after using both the Mi Max Prime and Mi Max 2 for quite sometime now!
In the games I play! SD625/506 lags like hell. However, SD652/510 performs so so much smoother or not so lag!:s22::s8:
Kiwi8
Deluxe Member
In the games I play! SD625/506 lags like hell. However, SD652/510 performs so so much smoothly or not so lag!:s22::s8:
Therefore, it is time for me to make a decision ......:D:D:D
The problem still remains that searching for 'mi max' still comes up with sales of 'mi max 2' too. So now which stores are still selling mi max?
kelvinti
Haven't you search Carousell, Qoo10, Lazada, Shopee and etc..?
Asphodeli
just bought a 64GB sandisk microSD card at house of mouse for $31.90. cheap and good. :o
seems to have helped battery life a little bit (about 30 mins more?) on my xperia z3+. now i know why my phone keep ejecting and prompting me to fix my old samsung 32GB SD card...
i1magic
Crap. My high specs Samsung microSD card also got that prompting to eject. Then it causes battery drain. I wonder anyway to fix them?
Asphodeli
dunno leh. my samsung card seems okay on my mi max, though. i think it's related to phone temperature, as my z3+ has heat dissipation issues. so it might work on cooler devices.
keigo22
the latest mui remove the feature of hotspot where you can set the limit of device connection and also blacklist the device.
That is a good feature don't understand why implement already and then remove it.
cscs3
Yes, quite disappointed.
