Xiaomi Mi Max - Part 2
Jhyun
I took your advice and changed the microSD card. This is the battery life now. Unplugged from charging for 23hrs and get SOT of about 7.5hrs and still got 19% battery left!
I am reluctant to change because the microSD card is the high speed one. But it seems to be the culprit.
Glad you found the culprit. Speed on the microSD card doesn't really make alot of difference unless you got thousands of photos lah. Still better to use one that doesn't cause any battery drain.
Shib
I am surprised sdcard can affect battery life...
Techno Pride
Hi. Any idea where can try Global Beta Nougat 7.5.25 ??
download for Mi max 64/128gb.
The 7.5.25 is in the year.month.day format, meaning it was released on 2017.05.25.
Please note there is a cut/copy bug if you try to cut/copy the URL in Chrome. The topof the Chrome window gets cut off and requires a restart of Chrome. Apart from the auto brightness bug mentioned by others of course.
ngbc
True, true! Better than nothing as some of us can flash to eu rom to experience MIUI 9 first hand then. :)
I hope that Mi Max will be in the 1st roll out list.
Users with the following devices can apply as MIUI 9 Beta Testers :
Mi 6, Mi 5s Plus, Mi 5s,
Mi 5c, Mi 5, Mi 4S, Mi 4c, Mi 4, Mi 3, Mi 2/2S, Mi MIX, Mi Max 2, Mi Max, Mi Note 2, Mi Note/Pro, Mi Pad 2, Mi Pad 1, Redmi Note 4X (MTK), Redmi Note 4X (SD), Redmi Note 4, Redmi Note 3 (MTK), Redmi Note 3 (SD), Redmi Note 2, Redmi Note, Redmi Pro, Redmi 4X, Redmi 4A, Redmi 4, Redmi 4 Prime, Redmi 3S/Prime, Redmi 3, Redmi 2A, Redmi 2/Prime, Redmi 1S, Redmi 1
However,
The following devices will get MIUI 9 beta update first: Mi 6, Redmi Note 4 Qualcomm / Redmi Note 4X! :(
source: http://en.miui.com/thread-697553-1-1.html
kelvinti
Long wait...:eek:
Anyway, I'm in no hurry since the current MIUI 8.2.3.0 work so well!
kelvinti
8.5.1 OTA here liao.
OK. 32 variant only...
Can check if the auto brightness works properly especially so after you switch off the auto brightness that the brightness level returns to the preset manual level fast and correctly?
