Xiaomi Mi Max - Part 2
kelvinti
It's time to go eu developer rom or China developer rom for early adoption of MIUI 9!:s22:
August 25th, 2017
MIUI 9 China Developer ROM for Mi MIX, Mi Note 2, Mi 5, Mi 5s, Mi 5s Plus, Mi 5c, Mi Max 2, Mi Max 32G, Mi Max 64G/128G, Mi 4S, Mi 4c, Mi Note Pro, and Redmi 4X will be released to the public!
As usual! Global rom can wait long long a bit...as long as the Great Wall of China lah..:s8::o
Lil_d3viLz
Why mi max price increase so much? It is like impossible to find it at prices like that anymore. No wonder mi max 2nd hand still sells well.
32gb = $220
64gb = $260
128gb = $310
dest86
Hi. If we buy the export set mimax2, so if anything spoil with the phone ,I understand we can't go to service centre.so who do we seek help?
kelvinti
Mi max2 is downgrade cost down version of mi max.
32gb = $220
64gb = $260
128gb = $310
Ya lor! Why ahh? Max 1 is a damn old model already (1.5 years old ).:s11:
Even sellers in Carousell are still trying to chop carrot head with their old Max 1 sia! :vijayadmin:
kelvinti
Hmm... No lah. Got certain parts upgraded and certain parts downgraded lah in order to keep the cost and price as it is.
Cannot say a total downgrade leh..
Having said that. Xiaomi has made a bad decision to downgrade its CPU, memory chip and LED bulb among all the parts...
Lil_d3viLz
CPU really so much difference?
kelvinti
Take it as a combi of lower SD625 + Adreno 506 + Single Channel Memory. You feel the lag started kicking in faster in prolong usage be it apps or games.
Max 1 Prime is a SD652 + Adreno 510 + Double channel memory.
nuilnuil
Anyone know any shop that can replace MiMax battery.
The battery like bloated causing the screen to be curved.
Lil_d3viLz
Really? If I avoid games totally, basic watching of videos, youtube, browsing, should be fine? In that case MM2 > MM1 due to longer duration?
I only play 1 mobile app, Summoners War.
cscs3
Seem quite common for Xiaomi phone. Got it on my 1s,Mi4i and Redmi note 2. Lucky 1s and note 2 cover is removeable for battery replacement.
kelvinti
As per your usage pattern. Max 2 is fine with you. Basically, media usage is fine.
I only know that Summoners War is running super well on Max 1. I'm not sure about it running on Max 2 though...
Personally, I'm more particular about it or rather more sensitive towards those micro lags as I have been using Max 1 Prime for long.
For normal users, they may not be that particular or sensitive about it.
Lil_d3viLz
Can I have the full addresss? Thanks.
Hmmm.... Jurong West Blk 463. Near busstop. Forget number. Hmmm.... Better call to make sure they got the battery stock. If I not wrong, most sellers don't buy battery part. Not much sales if buying in bulk.
1982-1994
32gb = $220
64gb = $260
128gb = $310
Those mentioned prices are used sets?
I sold my 32gb at $180 and 128gb at $270.
