Xiaomi Mi Max - Part 2
kelvinti
For the EU ROM, possible to disable the swipe up to search?
< Update >
Yes. You can disable it. :)
Shib
Any recommendations to stop notifications at night during sleep? Any app or settings to tweak?
Techno Pride
< Update >
http://i.imgur.com/PJfxKFB.jpg[/QUOTE]
thanks!
I got a cheapo spare Xiaomi to test flashing EU ROM. Have unlocked the phone. Now awaiting first boot into EU ROM.
[img]https://imagetroll.com/2018/01/hm4x_eu7.12.7.png
George Soros
BTW, can you boot up into fastboot mode?
If can. Then, probably can install twrp and then flash to eu rom first. After that, flash back to official rom.
cant boot into fastboot mode, even fast boot mode also need press the vol +- and power button right?
kelvinti
hmmm battery prob how much the market rate to change it?
btw, today my colleague, the front screen pop up at the side..suspected battery bloated..used for 13mth..
Not sure how much is the battery replacement fee. It should be much cheaper than replacing a broken screen..
Bloated battery, should be your friend's case!
Techno Pride
I've to wait ~12 days before unlocking my Mi Max bootloader. In the meantime, how do I backup most of my apps, to make it easier to copy the data and settings to the new EU ROM?
Settings -> Additional Settings -> Backup & Reset. Then go into Explorer on phone and copy out /MIUI/backup/AllBackup/?
kelvinti
Ahh! Wait for 12 days? Not 72 hours?
As for the backup and transfer thingy. Me no idea siol...
Techno Pride
Oh it works now. Sorta.
The designers changed something in the ring/silent feature. I played around the settings there and it now vibrates fine.
The Silent toggle doesn't light up properly though.
The Silent toggle works fine after enabling MIUI optimization in Developer Options.
kelvinti
You flipped prata between global and EU beta again? :D
Sent from 白イヌめブコロス using GAGT
:s13: :D Flipped prata for a while already....3 weeks ago or rather I have been running 3 versions of Global Beta rom already! =:p
I like the cute cute animated apps icons in Global Beta which includes the WhatsApp and Facebook animated icons..=:p
kelvinti
So far for all my apps. The only app that gives problem with Global Beta is that the DBS app. It refuses to let me set up fingerprint login whereas with eu rom, it allows.
Anyway, it is not a deal breaker as I use the app once in a while only.
** Magisk rooted with Global Beta.
Shib
Wow! Welcome back. Haha
Shib
Anyone on the HPB step challenge? Found that the step tracker cannot Bluetooth connect to Mi Max.
