Xiaomi Mi Max - Part 2
George Soros
hi,
is there anywhere shop that can help to fix the bootloop bug on my mi max with a small fee.?'
i try to do online based on the instruction but too many not sure which is the correct one..
haiss
s
MIVEC525
hi,
haiss
s
Mobile hardware
cscs3
hi,
haiss
s
Go Miui community to find procedures to fix it. You need to download some program and do it with PC.
Shib
Another update.
kelvinti
Yes, and that finally, the last 2 versions of global beta has been quite good. :)
kelvinti
downloaded and try follow but when plug in cable seem not detected.try many solution feel like give up..:(
Can you go into EDL mode (total blank screen)?
If can, then download official rom (Stable or Beta), and then flash the rom using the official MiFlashTool (Latest version or Beta version).
** I have to use the MiFlashTool Beta version with my PC. The latest official version doesn't work with my PC.
George Soros
thanks for trying to help.
first, i download this few tool and fast boot rom https://imgur.com/a/YToLm
then i follow instruction try to boot into edl mode by press vol+, vol- and power button together..there no respone..but when i plug in phone to charger, it will show mi logo..trying to charge for certain hour for the battery to get full and see how...:(
kelvinti
i trying to follow this guide
http://en.miui.com/a-234.html
Hmm...Yeah! Fully charge the battery first.
Techno Pride
My latest Global Beta ota update 7.12.28 can't vibrate.
The physical motor works fine as there is one instance of vibration during bootup. Then after it boots into the OS, vibration doesn't work.
kelvinti
No problem for my vibrator here. Just tested receiving a WhatsApp. It vibrates with sound or it vibrates in Silent mode as well. :)
Please reboot one more time, can?
Techno Pride
Oh it works now. Sorta.
The designers changed something in the ring/silent feature. I played around the settings there and it now vibrates fine.
The Silent toggle doesn't light up properly though.
kelvinti
after charging few hours, press vol +and- and power button also no respone...dont feel any vibration
Hmm... Possible bricked or battery problem?
I can't advise from here then. :(
However, try the below guide to see it works if you haven't done so.
http://en.miui.com/thread-305827-1-1.html
George Soros
hmmm look on the thread prob is i cant turn on the phone so somes step not able to do it.
example step 3 n 4
kelvinti
BTW, can you boot up into fastboot mode?
If can. Then, probably can install twrp and then flash to eu rom first. After that, flash back to official rom.
