tiertime
- Jan 20, 2011
but i thought both are 6.44 inches..![]()
Design is different. Think Mi Max 2 more round at 4 corner.
Design is different. Think Mi Max 2 more round at 4 coner.
I own both model. Camera position also different so Max 1 case cannot be be on Max 2 and vice versa.
You mean the lightning bolt with a circle surrounding it? It's still thereerr anyon'e quick charge icon seems to change back to original charging icon after the update?
Sometimes, it depends on the charger you use. I'm using an aukey qc2.0 one and the QC icon appears most of the time for meYup, crap mine is gone after the update. Happened for both of my mi max of 64GB and 32GB.
You can on off the adapter and see. Most of the time should be able to super charge.Yup, crap mine is gone after the update. Happened for both of my mi max of 64GB and 32GB.
it works, thanks. My charger is on all the way usually.You can on off the adapter and see. Most of the time should be able to super charge.
Sent from HUAWEI MATE 10 using GAGT
Hmmm...They should be in the DCIM folder. Have you browsed that folder?
Sorry this is so late, but yep - checked the DCIM and it wasn't there. Weirdest thing ever.![]()
It's face down with the screen facing you. Don't be so anxious. If you can't put it back in how did you eject it in the first placei bought a Mi Max (ver.1) and the sim card slot is face down, is this normal? now i tried to put it back in
face up it cannot close slot,
face down also cannot close slot...
is it suppose to face up or down? (if my phone screen is facing me)![]()
You mean the metal plate which supports and aligns the SIM card?i managed to put it in face down now, but the thin silver handle came off as the screw came lose ...![]()
Cannot screw back?![]()
the screw at the handle , 1 side came off... how to fix/ secure ar?.. can put scotch tape or super glue?
Cannot screw back?
great idea! thanks for suggestion, i am just shopping on Taobao hv to check out by todayjust super glue, wait for it to dry then slot back in?
pretty sure you can buy this tray easily on taobao
