Xiaomi Mi Max - Part 2
luei74
Forgot where to find 'allowed app to run on background' setting? Or is there one? (Only can manage autostart apps)
Settings => Additional settings => Developer Options
touchme
thank you sir, found.
Didn't describe as 'allow run in background', but as inactive apps, where you enter to toggle active active/inactive (default). Would this means 'allow run in background, not does not auto-start'?
luei74
https://www.techtolead.com/find-the-list-of-inactive-apps-in-android-device/6798/
If you are app lover and interested in exploring each and every trending app that was launched, then you must have ended up with many apps installed on your Android device. But after installing the apps, a few days later you might not use all the apps you have installed on your phone. This might cause low memory/space issues and also lack of device performance. In this situation, it is hard to find out the inactive apps easily and uninstall them. Here is a quick solution to find the list of Inactive Apps on Android device.
How To Find The List Of Inactive Apps On Android Device:
Step 1: First, Enable the Developer Options on Your Android smartphone. Check out the steps here.
Step 2: Now Go to Settings > Developer options and then navigate to Apps sections.
Step 3: Under Apps section, you’ll find an option called Inactive Apps. Tap on that option.
Step 4: The Inactive Apps page will list you all the apps with Active and Inactive status based on your usage. You can also tap on the apps to make them Inactive or Active manually as well.
Step 5: Now you will get the list of Inactive apps in your android device.
The list helps you to uninstall the inactive apps which you haven’t used for many days. I recommend you to try this method on your Android devices [smartphoen or tablet] and save some memory/resource for better performance on your device.
I think is meant for user to Uninstall those less activity apps :)
luei74
Do you need to use any converter to 3pin plug to use this? And transformer needed?
Just get the 2 pin to 3 pin converter will do, neighborhood shop should have it, no need transformer as the AC supply is from 100-240V..
Input: AC100-240V 50/60Hz 0.5A
sjchai75
Thanks bro.
Niaoson
Bought in July 2016. Almost two years and battery seems to not be able to hold charge as well but still hanging in there :o
luei74
This ver9540 is very good!!
Phone totally in deep sleep as compare to the previous version
Sausage
Mine is prompting for 9.5.4.0nbcmifa instead. Does this one have any known bugs?
luei74
strange...mine is 9.5.4.0(NBCMIFA), similar to Just Me
So far so good and running fine, battery usage seems to improve as compare to the earlier version...
kelvinti
Mi Max folks! Long time no see! :s13:
I just got a 1.2G full "package" prompt of 9.5.4.0! :s8:
*Updated to 9.5.4.0 and re-rooted! No issue so far! :)
Just Me
For me, the weather location is not working again after updating. You can manually select sg only
tiertime
Hi, can anyone advise if i buy a Xiaomi Mi Max 2 phone cover flipcase, can it also fit for a Xiaomi Mi Max (1) model ?
