Xiaomi Mi Max - Part 2
Just Me
screw is not turning type, once fall out it cannot put back in.. its like a "tapped-in-type", very fragile ..
great idea! thanks for suggestion, i am just shopping on Taobao hv to check out by today :)
any idea how to search that in chinese text?
No need buy from tb.. AliExpress has it
New For Xiaomi MI MAX SIM Card Tray Slot Holder Adapter Replacement Parts
http://s.aliexpress.com/m63u2IJb?fromSns
cscs3
Taobao do support search using English text.
sjchai75
My Max battery drain very fast nowadays, cannot last one day of use. Anyone have same issue?
luei74
Did you already on the latest firmware 9.5.4.0? Noticed the previous FW tend to drain more power..
Shib
I wonder they using the same Apple trick or your battery is dying? I have not updated my set firmware.
Sent from HUAWEI MATE 10 using GAGT
luei74
Yes, on 9.5.4.0 already
Mine about 21 months still can last for 1.5 days after full charge... Maybe it's time to get a replacement if you still considering using it. I'm just ordering 2x BM49 from Taobao today (one for my daughter set).
sjchai75
You are ordering the battery? How much? You change yourself?
luei74
Hi bro, if asked you to buy extra for me, how to collect from you?
My order is already processing bro lol....Got the info from the max3 thread actually.... Sensitive Sea might take a while to reach to Singapore... Another option for you maybe can check with those Ah Beng shop at SLS for the battery replacement? :)....I heard $40 only for battery replacement
sjchai75
Noted bro. Maybe get from aliexpress
tiertime
i have a general inquiry for xiaomi phone,
i have a 5.7" Mi Note, its a refurbish export set, i realised it got 2 sim card slot but both imei number is identical... does it mean that one of the simcard slot is not working?
kelvinti
Not sure! However, have you tried both sim slot with 2 different sim cards?
tiertime
havnt, my sim card is cut very closly to the edge, im worried i may tear the outer frame if i push out the smallest sim
my xiao mi has 2 sim card slot, one for bigger sim and one for smaller, but both with identical imei number
ZrE0_Cha0s
Hmm..that's werid cos u shouldn't have same IMEI number for dual SIM slot.
tiertime
the nano sim card slot i finally tested yesterday and its not working, only the Micro working,
So means if both IMEI number is same, it means that one of the SIM card slot does not work...
