Xiaomi Mi Max - Part 2
kelvinti
Hmmm... Random restart and nothing to worry about!?
Very high level wor...
Oinkize
If it's a one off ramdom restart do you worry?
When was the last time the phone was being rebooted?
Is the random restart often?
Oinkize
Anyway if it happens frequently, local set bring go sc else reflash and monitor.
trichard
I think also because I play with the developer menu... The memory optimize is what by default ? I set to high and I off mumi optimization.
kelvinti
OIC! Probably due to that lah.. Haha..
Memory optimization is "Middle" by default.
kelvinti
Muiu optimization as off?
That's ON by default but that should not trigger random reboot by setting it to OFF..
It should be due to the High setting of Memory Optimization lioa...
Make sure you reboot your max after changing those settings back.
trichard
K..............................
kelvinti
To all Mi Max users!
祝大家新年快乐! 身体健康! 出入平安! 萬事如意! :s22:
Max Happiness! Max Healthy! Max safety! Max....hmmm...As You Wanted To Be lah! :)
Umbrella Corporation
Collected my 128GB ytd from New Star.
Set was sealed and was opened in front of Mi, phone shows to be global ROM aldy. But after I test a bit in their shop, the playstore kept clashing and the guy Claims it to be a 3rd party ROM actually.
However He was kind enough to flash it to the Official global MIUI 8 on the spot.
Flawless afterwhich and loving my new phone every min, very good buy personally.
Service wise I would say approach the slim specky guy, very patience with customers. Others are just busying toking among each other although there are customers waiting to be serve.
Now just waiting for my 128GB sdcard to arrive��
