Xiaomi Mi Max - Part 2
tadpol387
Hi fellow bros & sis.
I dropped my xiaomi Mi Max earlier today and unfortunately created a dent to the volume button.
And now I can't control volume nor press the power button TnT
Kindly advise on how or where I can get it repair.
Thanks in advance for your assistance.
pilico
Try dismantle it and undent the button.
If you go to shop, i bet they will charge more than 50 dollar.
anirudhks
Just search a few posts before I posted to remove and replace it yourself is easy SLS has a shop that you can buy Parts for about 5 or 7 $ if no hurry order from aliexpress
Sent from HUAWEI MHA-L29 using GAGT
tadpol387
Yes just called and they're quoting me 40 - 45 bucks. So expensive.
I've no experience in dismantling nor do i Have the tool to do so.
Any advise?
yusoffb01
Just finished flashing LineageOS 7.1.1, no more Xiaomi bloatware. :s13:
The disadvantage is that no Xposed for Nougat, OG youtube can't access account without installing an older version + 3 apps with way too much permissions. :(
hows battery life and does gps work? xiaomi bloatware is not an issue with root can remove. I quite like the battery life on stock, up to 10h screen time over 5days
1982-1994
so is the phone on now?
activate the double tap (in order to on the display)
and download screen off on playstore. and place the app on home screen so that you can off the display by hitting the app.
tadpol387
Hi bro, yeah its on. How do I go about doing the above the mentioned setting?
iScream
Killed my 3/32 while snorkeling in Krabi. Went back to an iPhone and now miss the big screen that the Mi Max has. Any good deals ongoing? Cheapest i could find is for 3/64 at $279 with 6mths warranty.
cscs3
Any advise?
Keep it for spare part and buy a new one. New set are not expensive now.
virus2977
U can use a plastic opener to open the back cover then bend back the button. I open mine before. Must start from below corner. Mine worst than you. Need to buy part from aliexpress diy repair..lol. maybe you buy the back cover then take the volume button out replace to old back cover.
zibellino
this is the best part about xiaomi phone everything broken can diy yourself even lcd is not that expensive at aliexpress
falcom2002
I am still not having any sd card on my Mi Max 32GB yet.
Can brothers here kindly confirm that if I put in any brand
of either 64GB/128GB sd card, I don't have to do
any Fat32 formatting with my PC.
All I need to do is to insert it into the phone and format the
card using the phone. Next step is, can show me how
to do the formatting using the phone? Thanks. :s11:
biue22
Din encounter any problems with my Sandisk 64gb. I just insert and reformat on my phone.
