Xiaomi Mi Max - Part 2
zibellino
Did you flash it with or without unlocking the bootloader?
How's the performance thus far. Looking to flash it :D
now i using nitrogen os by marchetto96 much better than lineage and more smoother but cant save camera to sd card the only thing missing.i am on unlock bootloader btw.flash nebula v2 if you dont like the stock kernel.
tjkb230
Just joined the camp! Will be used as a spare phone.
Phone came with global rom installed (8.0.3.0), eliminates all the China rom and flashing issues discussed previously yippee! :D
Immediately updated it to (8.1.9.0). So far so good.
Overall it's pretty good. Much more responsive than my previous Redmi Note (3G) bought in 2014. But the huge size will need time to get used to it.
Sorry Xiaomi will have to be my spare phone always. Haha!
G4
thinking of getting the Mi Max 64GB for gaming leisure use. can use 128GB microsd?
lionelfoo
Hi all, just got my Mi max from qoo10. flashed to global rom. just to check. was told by the shop that i can't restore my phone, if i do that i will lose the google play store. Can i check if it is true?
kelvinti
Nonsense lah... They don't know what they are talking...
If yours is an official global rom, then no such thing as losing Google after restore coz Google is included in the official global rom.
Show us the screenshot of your About Phone to make sure it is a real official global rom.
lionelfoo
http://imgur.com/a/2gbzq
And another 2 question! anyone managed to put 2 sim cards and 1 microsd card?
If i use dual sim. can i not allow incoming calls from Sim 2 and to use all my data from sim 2?
Oinkize
Someone did it before. Either through some hand craft modification another by using an adaptor bought from taobao.
You can do call barring for sim 2 and use it for data only.
Krabs.
the 2 sim card + microsd trick was shown in photo earlier in this thread , use scotchtape , but got risk dunno what can get stuck inside
stylechap
it could be the shop just flash fastboot rom in your phone
kelvinti
Finally...
It has been so long since 8.1.6.0 for Mi Max and 8.1.9.0 for Mi Max Prime. :)
s1mple
Happy with new case, bought from AliExpress:
