Xiaomi Mi Max - Part 2
kelvinti
Happy with new case, bought from AliExpress:
Hmm...You like colorful isn't it? :)
Look at your keyboard.... :)
dralf
I bought my max a week ago from qoo10. seller said is global rom.
Noticed that contacts got problem. When click into any of my contact, will have error.
unable to update to latest global rom using the updater in phone.
mine is not a real global rom?
justln
mine is not a real global rom?]
If you can't update using the inbuilt updater then it's a fake ROM. Go flash an original one.
kelvinti
Your seller bluff you de...
Yours is a hacked China rom.
No wonder you experienced Google contact issue.
You must Fastboot miflash to official global rom liao... :)
Remember this folks. Anything with the "CN" in the MIUI version section is a hacked or official China rom.
kyiori
u got from which seller at qoo10? so new buyer can aware and avoid from it.
dralf
Bought from SIMDER TRADING.
Got step by step guide for me to flash to global rom?
I very noob one. Scared will brick the phone.
Thanks in advance!
kelvinti
Basically most sellers are more or less practice that bluffness de..
They will bluff through the buyers who do not have much knowledge about the differences between global and China or hacked or 3rd party rom de...
pearl_ml
hi folks, i have no concern over 32/64gb storage or 3/4gb ram. would like to know snapdragon 652 got any performance advantage over 650 beside 2 extra cores?
kelvinti
Thanks in advance!
I bought my gf Mi Max from Simder Trading too with a hacked China rom as well.
gniljia
Hello there!
Will like to know if anyone here experience issues with notifications? Such as, I dont receive notifications from telegram and carousell, two apps I use rather frequently. I have to go into the app before I see the messages. The notifications will be fine until after say 3-4 hours later, then the notifications shopper again! I tried to set them as priority but not helping.
Also, after setting some of the apps as priority, the apps will continue to show notifications when I am on DND mode. Not cool when I was in midst of something else and dont want to show the notifications.
Any way to resolvs these two issues? :)
Thanks in advance!!
cscs3
Hello there!
Thanks in advance!!
Normal. WhatsApp too. On and off. Certain firmware is good and not for some. Has to live with it till you find a good release and freeze there.
Lock application in memory helps a little. But if you have lots of program facing same issue and need to do the same. It means you have less memory to run other applications.
cscs3
7.x.x version and "CN", I think is developer chinese version?
kelvinti
Now, see who is the first few here to get the Global 8.2 today.... :)
Today is the official release of Global 8.2.x.x rom. :)
gniljia
I tried looking but that didnt help. Well shall wait for the next firmware then heh
Thanks!
cokiee
Heh that keyboard costs as much as the phone!
Hello there!
Thanks in advance!!
I have the same problem with carousell actually. Lost me a couple of deals, but thankfully it doesn't really matter here.
Sent from Xiaomi MI 3W using GAGT
Jhyun
Thanks!
Lock the app, enable Autostart, under "Manage app's battery usage", set the "Power Saving in Background" to "No restrictions" for your desired app?
I have mostly no problems with Whatsapp and especially carousell after doing this.
