Xiaomi Mi Max - Part 2
kelvinti
It hasn't pushed to me yet too... Will just download manually and update after my lunch....
fffrozzz
received my mi max on monday to replace my old and trusty redmi 1s. been using for almost 3 yr, worth every penny. 1 of the best wifi reception at my site even iphone 5 can't match it. and my mo max rom,
kelvinti
Welcome to the Max family, bro! :s22:
Press harder to get the OTA 8.2.1.0 :s13:
kelvinti
My Mi Max 128 has been updated to Global 8.2.1.0 :s22:
So far, so good! :)
However, low volume on YouTube via headset is still not fixed. :vijayadmin:
Mi Sound Enhancer is still not working. :vijayadmin:
chengsun
Is there any shop that has the physical phone that I can play with a while? I am thinking to hoot 1 basic model (2GB/16GB) to use as ebook reader and maybe watch videos...
kelvinkezz
I think I saw it at challenger. Otherwise can go to the Xiaomi retail store at Suntec
kelvinti
The price between a 2/16 and a 3/32 is not much of a difference!
I would suggest you get the 3/32 model even just to watch video and for ebook reading!
2GB of RAM is so.....not enough considering the graphical design and contents of Apps now.... Very fast you will feel the lagginess de with just 2GB of RAM! Can vomit blood de.... :o
dralf
Just updated my Mi max 128gb, so far so good.
For those who can't wait, here's the link.
went into the link.
I can see the link for Mi Max Prime V8.2.1.0 Recovery Rom.
But why they put Fastboot Rom as "coming soon"? :s11:
I thought the file should be the same? just diff method of flashing?
anyway I just flashed using via Mi updater App.
It states that I am flashing to older version even though I'm using the latest V8.2.1.0.
after it auto reboot, still shows the same fake version :s22:
think i need to flash using fastboot liao :(
Krabs.
2gb don't have global rom because is only released within mainland china via their telco
sohnice
Fast boot & recovery both have liao for Mi max & prime. Direct MIUI
went into the link.
dralf
still cannot flash using fastboot mode.
encountered this using XiaoMiFlash.
tried using Mi PC Suite "MiSetup3.2.1.3111_2717.exe".
cannot detect phone when i am in fastboot mode. got this msg. "Try connect in Normal mode first then switch".
then when in normal mode, cannot detect. it states "Connect your device via USB"
Then after awhile the msg changes to "You need to update your device to use Mi PC Suite. Update your device before connecting"
stuck:(
stylechap
stuck:(
did you install the drivers for your phone?
http://en.miui.com/thread-307139-1-1.html
