Xiaomi Mi Max - Part 2
kelvinti
still cannot flash using fastboot mode.
encountered this using XiaoMiFlash.
tried using Mi PC Suite "MiSetup3.2.1.3111_2717.exe".
cannot detect phone when i am in fastboot mode. got this msg. "Try connect in Normal mode first then switch".
then when in normal mode, cannot detect. it states "Connect your device via USB"
Then after awhile the msg changes to "You need to update your device to use Mi PC Suite. Update your device before connecting"
stuck:(
Kekeke...:D "That is awesome"=:p
Missing Quadcomm Driver 9005 lah! You didn't install is it?
Else, the Device in the MiFlash program should show between "COM01 - COM10". Then, you can flash. The process should take about 10 to 15 minutes! :)
orion77
My Mi Max 128Gb suddenly restarted and is in a boot loop. it will show the mi logo over and over again upon start upon, tried to re-flash it, but no avail. Have tried to send in to Xiaomi Service Center SG at Central, but they dun repair export set. Anyone knows where i can send in the phone for servicing?
1982-1994
maybe try EDL mode by holding both volume and power buttons at the same time, connect it to your pc once the phone vibrates.
komade
Any adaptor that can fit in the hybrid sim slot that can accommodate the sim card and microsd?
ZrE0_Cha0s
can I know the current cheapest price of the mi max 32gb?
i think u can try looking into shopee, as currently i dun think qoo10 have any good coupon on going right now.
else can consider looking into lazada with today dbs and posb 8% discount (but need to check max cap how much)
ZrE0_Cha0s
well u can buy those ppl have those extend out for holding a 2nd sim.
just look for a few previous post or page.
kelvinti
Oh Ya. Those we are new to Mi Max.
There is a tilt shift effect mode for photo taking. Quite nice effect.
There is also a time Lapse in video mode. :)
kelvinti
1 more thing, i saw HD logo when making a call and the network is H+ (using Starhub)
Still no VOLTE though.
Same same here with StarHub.
As for the fingerprint, I actually like it without vibration (with unlock sound ON) when unlock successfully.
It vibrates only when it failed to recognize your fingerprint.
i1magic
For those who don't want to do the SIM card migration to microSD card surgery, can get this.
Somebody asking for the Dual SIM adaptor.
Please see the link in the description. Also, there are 3 model, the 1st one should be the same one that I tried. The 2nd one allow 2 SIM card (instead of 1) but I'm not sure whether can the phone support.
i1magic
Recently, my Mi Max get the "auto reboot" symptoms.
Any of you get this too?
