Xiaomi Mi Max
just weird having slow dling speed for big files on playstore (even for wifi)
Ya..my prata set 32GB also the same...download speed 4G or WiFi 1mb per second..for example the apps is 30mb it took like 30sec to download...don't know why like that even do a hard reset it still the same...!
NCMK
Keen to buy the 4G/ 128GB model. Saw some ads with quad core and some with octa core? Abit confused on the model. Where is the cheapest and best place to buy?
1982-1994
Just got the Mi max 64gb.. Comes with this version
So it does not auto update to the latest version? Can be done with dragonguy instructions to update to miui 8?
I'm on 7.3.14 and my 32gb variant does prompt up the latest update notification.
V8.0.3.0
DRAGONGUY
ok guys! i finally managed to flash and unbrick my phone. i think it was a combination of factors that made my flash fail and soft bricked my phone last night.
1) using an old xiaomi flash beta program
2) cranky front USB port
3) trying to flash in flashboot mode instead of EDL mode
4) i had the qualcomm drivers but phone appeared as qhusb_bulk thingy, so had to reinstall
5) using the xiaomiflash STABLE program DID NOT WORK for me
in the end, i used everything from the miui 8 mi max prime thread, the beta flashing tool and the qualcomm drivers.
anyhow, thanks dragon and kelvin for any help rendered!
Congrats.... enjoy ur global rom...
KinMun1989
If I don't want to go through lazada or qoo10, any shops that sell export set to recommend? With shop warranty at least 2 weeks in case.
jace88
My SG MiMax just started an auto update to MIUI V8.0.2.0.MBCMIDG | Nightly | 1.4G
Only update is "Improved system stability".
Pity it's so slow to update on my free wifi at work. Wish it was doing this at home.
kelvinti
Folks,
After I flashed back to 8.0.1.0, my pc die die does not want to recognize my Mi Max in MTP USB mode...
Already tried installing the Xiaomi driver, but still failed. :(
I cannot gain access to the mi max storage.... :(
What could have gone wrong?
Compact7
Walk in price may be different from lazada listed price..I asked before. You can call them to confirm.
Btw, Xiaomi lazada store is open 14 Oct. Maybe special discount + 1 yr warranty? :s13:
Oinkize
Folks,
Try another port or pc?
chm527
Folks,
Not a MiMax user, but for my MiNote, it only recognises the official usb cable. Cannot use any OEM usb cable.
kelvinti
Ya oh.. Thank for highting that. :)
I'm using a Redmi Note 3 cable. Let me try the original Mi Max cable....
