Xiaomi Mi Max
element
Mi max
Hi, heard using mi flash to flash Fastboot rom on 32 bit pc will result in bricked device. Anyone done it successfully? I only have 32 bit pc at home =(
i1magic
I saw at Challenger last evening that if you buy Xiaomi Mi 5 for $619 and you get FREE Xiaomi Air purifier.
Oinkize
Erm this promo has been around for quite awhile already.
Mi Max $349 free pb and selfie stick.
FinchGuy
Anyone has copy & paste problem? I copied a phone number using long press, message said Copied to Clipboard, but nothing appeared when I try to paste it.
kelvinti
What keyboard was that?
I'm using SwiftKey, no problem at all for any copy and paste function... :)
kelvinti
As clearly stated. The basic requirement is a 64bits. There must the a reason for it.
Better don't try on a 32bits PC bah! Later kena bricked then LL! :o
Other flashing guru wanna comment on the possibility of a successfully flashing on 32bits Windows? :s11:
kelvinti
Anyway, folks,
Tested 3 different brands and types of headphones.
A LG QuadBeat 2, a Beats in-ear and an original iPhone earpiece.
YouTube playback via all 3 headphones models are the same...low volume it is. It isn't normal for sure! :s8:
Already reported to MIUI8 Team. :s22:
**Tested on 8.0.1.0, 8.0.2.0 as well as on the latest 8.1.2.0 (Mi Max 32GB)!
Chuz111
Can unlock bootloader, place ROM in internal storage, rename to update.zip and update via Mi recovery on the phone.
Or install TWRP (After unlocking bootloader)
XDA got many guides and a subforum for Mi Max
element
Thanks. My phone is running unofficial rom from shop so I can't use recovery to flash rom. This, need to use Fastboot to flash. Actu I only saw that warning in one post so not sure if it's really true or if it's updated info.
kelvinti
Don't take the risk bah!
Just use a friend's 64bits to flash. Less than a 5 minutes job. Not worth the brick on a 32bits.
kelvinti
Probably the most important thing to do is to disabled the driver signature verification before proceed.
shineshy
to all max users out there, like to check for 16gb & 32gb, how much spare is actually left for usage.
Thank you
shineshy
so based on 32gb usage of approx 6gb for software..i guess for 16gb model..probably left around 10gb left to install stuff..
kelvinti
Get the 32GB regardless of your storage usage.
16GB is just too little, too risky for long term.
You will never know....
