Xiaomi Mi Max
Bobby Goh
If you pay with PayPal, yes ... sure can get back $$.
Any other payment, wash your ass and get really to be screwed by Qoo10. They don't care about refund one.
Don't quite agree with the statement that they don't care about refund.
I've mentioned before.. ever bought Beats Studio Wireless that turn it to be fake. Managed to get a refund through contacting the helpdesk. Almost closed to $300.
tech_oasis
Have two sims, one for voice (little data) and one data. Is is possible to have one sim for voice an another for data? e.g. Sim 1 voice only and Sim 2 data only. Will Sim 1 be able to tap on Sim 2 data e.g. Sim 1 access Whatsapp using Sim 2 data.
Thanks
Oinkize
Thanks
Yes. 10 chars.
But when on voice call, data will suspend if data is from another sim.
Oinkize
not gonna share , just dont want to getinto trouble ..hehe , anyways yes this is the MIUI 8 Global beta rom .. the process of entire thing takes not more than 20 mins actully .. doesnt really take that long .. :)
I am on the modified global rom. there might be complications?
If i have time tonight, let me type out the exact steps to perform and you vet for me ok?
Ndrew
Hi,
I have been following the guide. My Mi Max already unlock, however when using Miflash to flash the rom, I unable to get through and encounter this error. Any experts can shade some light.
luei74
Hi,
Try:
-change diff port.
-change diff cable (I solved by changing w diff cable)
-put the file in C:\temp (simplify n don't put into so many folder)
Sent from 小米牛贰 using GAGT
anirudhks
Hi,
the error is simple you have nt downloaded the miflash package you have downloaded the recovery package
ferocity
Another one of my price check posts. Flydigital @ qoo10 selling 3gb/32gb model at $289 for gold(silver costs $10 more). Cant use coupons but can use 1000 qpoints to further offset $10 to bring the price down to $279. Self collection is possible.
Aicirt
Just collected the set....updated the software. Need some help...
1) Do i need to insert my simcard in order to sign into mi account ?
2) I've manage to install back playstore ....but despite being able to sign in , i cant download any app.
Just Me
Even qpoints are not so easy to collect as compared to last time. Miss the $5 offset gift cards for every $100 purchased too
Sent from Jiak Liow Bi phone using GAGT
ccn666
Bro, I assume that ur ROM will also work on Max 128GB, considering the fact that it shares the same SD652 chip with Max 64GB, right? :D
ok so here is the procedure , unlocked bootloader guys only who are using the 128GB or the 64GB model
install twrp
go to fastboot mode
fastboot format system
fastboot format userdata ( this is wil erase your local SD make sure you backup )
then press and hold volume up and power to reboot to the twrp
select the zip file downloaded and install and then reboot ( during the reboot twrp will say no OS installed ignore it )
wait for 5 mins to reboot and you now have a global rom on your 64GB Max :)
link
https://mega.nz/#!09Nm0AwI!ax9HPjrzunUO0F2nCEIYQz-Jo8gWpLFuo2uvkjteoIo
